Tuya app response
I noticed that controlling my H32B by kincony smart home app, the response is quicker more than by tuya app.
Why is that???
1 my H32B connected to router by ethernet cable, and the configuration in H32B is set as “UDP”
2.the tuya adapter configured as tcp connection.
when use tuya adapter by "TCP Connection", set H32B ethernet work mode = TCP Server.
Will correct myself:
Ethernet work mode= TCP Server
Wifi work mode = UDP
In this case i can use kincony smart home app and tuya app in the same time.
And i noticed that the response when i turn on any relay from kincony smart home app is quicker than tuya app.
Why is that?
test set wifi work mode = TCP Server too. just use only Tuya app.
