can i use kcs firmwar with kc868-16T ?
sorry, not support now. because E16T alreadfy have Tuya module on PCB. do you want the E16T support "KCS"?
Yes, these is good firmware that have high advantage
 When make firmware kcs for kc868-16T? Please
actually, you can download KC868-E16S "KCS" firmware to E16T board directly, you can use "KCS". just the wifi tuya module will can't work. if you want to use E16T by tuya application, you need to buy tuya licence is ok. if you don't want to use tuya application, ok, just download "KCS" to E16T directly.
using the KC868-E16S "KCS" firmware on E16T I can use it with HomeAssistant with ESPHome?
is there a guide for ESPhome with E16t?
"KCS" and ESPHome are two different firmware. you can use either one , just download firmware will overwrite the ESP32.
(05-22-2024, 10:41 AM)admin Wrote: "KCS" and ESPHome are two different firmware.  you can use either one , just download firmware will overwrite the ESP32.
where do I find the ESPHome firmware for E16T and guide ?
in the case of the "KCS" firmware do I have to use the  E16S firmware or have you prepared a new firmware for E16T?
Thanks
1. E16T ESPHome yaml file just use by E16S' here is link: https://www.kincony.com/forum/showthread.php?tid=2125
2. just use E16S KCS firmware.
my means: E16T new ESPHome ymal file will update after about 2 weeks.
