06-01-2024, 07:49 AM
Attached...
KC868-A16 Download, EtherNet Firmware and not open EntherNet
06-01-2024, 12:55 PM
when you download firmware, remove the RF433M receiver module, it will be solved.
06-03-2024, 11:13 AM
When I removed the RF receiver and transmitter and reconnected the module to the PC via USB cable => download to the module was successful.
Now the A16 module is available on the LAN and I can configure the inputs and outputs. Thanks for your help!
06-03-2024, 12:12 PM
ok, good.
I have a similar problem, but the result is different. the installation runs correctly, but the LAN port does not turn on after connecting the cable. when installing TASMOTA, I have access to the board via WiFi, the LAN LEDs light up, but I do not receive the LAN address via cable.
Web_server installation always ends the same, LAN does not work. LOG: *************************** START **************************** START TIME: 202408192221 CONNECT BAUD: 115200 set state: ESP_DL_SYNC serial port opened ----------- baud:115200 root baud:115200 ------------- ===============BAUD : 115200===============CALL DEVICE SYNC connecting... chip sync ok mac l: 0xf74947b4 mac h: 0xe008a6 crc_cal: 224 crc_read: 224 crc_test: 0 ESP32 MAC CRC OK get mac res: 1 get flash id : 0x0016405e manufacturer_id: 0x5e device_id: 0x4016 Wrote 743200 bytes (422165 compressed) at 0x00000000 in 37.0 seconds (effective 160.6 kbit/s)... Hash of data verified. Leaving... com closed Use time: 39 s Download result: PASS *************************** END ****************************
08-19-2024, 11:03 PM
when download firmware, remove RF433M reciever.
if you have problem, upload some photos , so that can understand. |
Users browsing this thread: |
2 Guest(s) |
