SD-Card in KC868-A16v3
I find no infos how the SD card works.
Is it just to safe log files?
To read the log files I must remove the card or is there any other way to access the datas?
do you have downloaded KCS v3 firmware?[Image: KCSv3-SD-Card.jpg]
[Image: KCS%20v3.1.0-SD-Card.png]
Thank you.
Yes I have the Firmware KCS v3 on my KC868-A16v3
SD-Card not so easy to access like on your B16M picture
I must fumble the SD-Card out from the board anytime I want to check the datas Dodgy
No other way?
Not a good solution.
yes, you need to get out, B16M is better, KC868-A is a Economic product solution, B series products is high quality and professional.
