03-24-2025, 11:31 PM
just re download KCS firmware to ESP32.
Etgernet + wifi
03-25-2025, 08:45 AM
(03-24-2025, 11:29 AM)kulibin Wrote:(02-06-2025, 10:54 AM)kulibin Wrote:(02-06-2025, 08:45 AM)admin Wrote: if use KCS firmware, let board integrate to home assistant by MQTT, not by ESPHome. Now I have KCS firmware. I want to go back to factory firmware to work with ESP Home. The firmware with which I bought
03-25-2025, 10:16 PM
if you want use by ESPHome, just download ESPHome firmware to ESP32, just overwrite it.
(03-25-2025, 10:16 PM)admin Wrote: if you want use by ESPHome, just download ESPHome firmware to ESP32, just overwrite it. Unable to install the ESP32 firmware. If I install the standard version of the ESP32 with WiFi, then everything works, and if I install your code with ethernet, then an error is constantly Code: Successfully created esp32 image.
03-27-2025, 11:14 PM
which board model you are using?
