[arduino code examples for F8]-11 Digital input trigger relay output
* This program reads 8 input states from a PCF8575 I/O expander and
* controls a corresponding 8-channel relay module. When an input pin
* is LOW, the corresponding relay is turned ON (LOW means ON for the relay).
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
* - PCF8575 I2C Address: 0x24
#include <Wire.h>
#include <PCF8575.h>
// I2C pins
#define SDA 8
#define SCL 18
// PCF8575 I2C address
#define INPUT_I2C_ADDRESS 0x24
// Create PCF8575 object
PCF8575 pcf8575_IN(INPUT_I2C_ADDRESS);
  Wire.begin(SDA, SCL);
  // Initialize PCF8575
  pcf8575_IN.begin();
  // Turn off all relays first (assuming LOW activates the relay)
  for (int i = 8; i < 16; i++) {
    pcf8575_IN.write(i, HIGH);  // Set to HIGH to turn off the relay
  Serial.println("System started: Input state controlling 8 relays");
  // Read 16-bit state from PCF8575
  uint16_t inputState = pcf8575_IN.read16();
  for (int i = 0; i < 8; i++) {
    bool state = bitRead(inputState, i); // Read digital input state
    Serial.print("DI");
    Serial.print(i + 1);
    Serial.print(" State: ");
    Serial.println(state ? "HIGH" : "LOW");
    // Control relay (LOW activates the relay)
    pcf8575_IN.write(8 + i, state ? HIGH : LOW);
  Serial.println("---------------------");
  delay(500);
arduino ino file download:
.zip   11-input-trigger-output.zip (Size: 898 bytes / Downloads: 743)
.zip   11-input-trigger-output.ino.merged.zip (Size: 189.63 KB / Downloads: 706)
