N20 Problem with Home Assistant Conection
Hello, I recently received an N20. I have access to it via Ethernet, but I can't connect it to "kinconyn20.local" nor can I connect it to Home Assistant. The strange thing is that it connects via MQTT from Home Assistant.
As soon as the device arrived, I flashed it to version v3 3.18.0. Its IP address is 192.168.3.78 (within my network range, OK), and its Wi-Fi access point is 192.168.4.1.
Is the problem that it can't access "kinconyn20.local"? Why doesn't Home Assistant recognize it?
I need to check the configuration of the CT clamps, as well as the L1 and L2 power inputs, which are not appearing.
I'm Spanish, sorry for the autotranslated English.
suggest you download KCS v3 firmware, enable MQTT auto discovery for home assistant, will be easy integrate to home assistant.
here is KCS v3 online guide: https://www.kincony.com/how-to-use-kcsv3...board.html
(12-27-2025, 08:44 AM)admin Wrote: suggest you download KCS v3 firmware, enable MQTT auto discovery for home assistant, will be easy integrate to home assistant.
I followed the steps and I still can't connect it to Home Assistant. It appears in ESPHomeBuilder but with an error.
I can access the device via web 192.168.3.78 (dhcp) but never via kinconyn20.local. Why doesn't it work?
Attached photo when kincony is in 192.168.3.78 and work kincony
Attached photo when in homeAssistant is online
Attached photo showing that, despite being online, it cannot connect to 192.168.78
I´m thinking of returning the device
After trying many methods, I finally got it working, though not without some difficulty. I managed to connect it via USB to the Home Assistant server. No other method worked, and I tried many. Connecting via IP gave me a lot of problems and headaches; Home Assistant wouldn't recognize the IP address, even though the device itself was working.
Now I'm struggling with MQTT. I can no longer access the device via IP. I can get the sensor data via IP, but not the configuration. I imagine this is related to Home Assistant.
I was about to return it... but we're going to keep fighting
we are check with N series board firmware, will have new firmware soon.
(12-28-2025, 11:57 PM)admin Wrote: we are check with N series board firmware, will have new firmware soon.
i like this, if i can do anything for help you i would like to help. Write me if you like to check the new firmware. Thanks!!!!!!!
1: update ARM CPU by USB-RS485 adapter, how to download firmware , see here: https://www.kincony.com/forum/showthread.php?tid=8863
2: update KCS v3.18.2,  how to download firmware , see here: https://www.kincony.com/forum/showthread.php?tid=8864
esphome is no problem, just you need update your ARM CPU firmware.
3: if your energy data is a very large number, first time, please use the new PC software to clear to 0. here is PC monitor software: https://www.kincony.com/forum/showthread.php?tid=8406   just download newest version:  APPV1.0.25.1231  https://www.kincony.com/forum/attachment.php?aid=8886
[Image: attachment.php?aid=8897]
[Image: attachment.php?aid=8898]
