(10-19-2025, 10:34 AM)admin Wrote: you can re download firmware. Or edit from home assistant for calibration.
hi
i bought a m16v2.1 and loaded into HA via esphome. however the input sensors dont show. i only see the firmware sensor as in the image. where might the issue be.
hi,
managed to get M16v2 integrated into HA via esphome. the route I followed was to do the initial setup in esphome, and then selected the install option. all went ok. the device was then discoverable by HA. When i look at it in HA it doesn't have the input sensors. see attached image. what is missing?
some information
just use our yaml file directly.
