B2 ESPHome yaml for home assistant with tuya
  friendly_name: b2
  platformio_options:
    board_build.extra_flags:
      # WIFI_CONTROL_SELF_MODE = 0
      # WIFI_CONTROL_SELF_MODE = 1
  board: esp32-s3-devkitc-1
    type: arduino
external_components:
  - source:
      type: git
      ref: v1.3.1
#   hardware_uart: USB_SERIAL_JTAG
  type: W5500
  clk_pin: GPIO1
  mosi_pin: GPIO2
  miso_pin: GPIO41
  cs_pin: GPIO42
  interrupt_pin: GPIO43
  reset_pin: GPIO44
   - id: bus_a
     sda: 8
     scl: 18
     frequency: 400kHz
uart:
  - id: uart_1    #RS485
    baud_rate: 9600
    debug:
      direction: BOTH
      dummy_receiver: true
      after:
        timeout: 10ms
    tx_pin: 38
    rx_pin: 39
  - id: tuya_mcu_uart
    tx_pin: GPIO14
    rx_pin: GPIO13
    baud_rate: 9600
tuya_wifi_mcu:
  # tuya mcu product id
  product_id: qk4eefxayleh2x5s
  uart_id: tuya_mcu_uart
  wifi_reset_pin: 28
  wifi_led_pin: 16
  - platform: uart
    uart_id: uart_1
    pin: 4
    inverted: false
  - platform: tuya_wifi_mcu
    dp_id: 1
    # hide from homeassistant ui
    internal: true
    bind_switch_id: "b2_output01"
    pin: 46
    inverted: false
    dp_id: 2
    internal: true
    bind_switch_id: "b2_output02"
      number: 6
    dp_id: 111
    bind_binary_sensor_id: b2_input01
    internal: true
      number: 7
    dp_id: 112
    bind_binary_sensor_id: b2_input02
    internal: true
##pull-up resistance on PCB
      number: 47
      number: 48
      number: 17
      number: 40
ads1115:
  - address: 0x48
  - platform: ads1115
    multiplexer: 'A0_GND'
    gain: 6.144
    resolution: 16_BITS
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A1_GND'
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A2_GND'
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A3_GND'
    gain: 6.144
    update_interval: 5s
web_server:
  port: 80
font:
  - file: "gfonts://Roboto"
display:
  - platform: ssd1306_i2c
    i2c_id: bus_a
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
      it.printf(0, 0, id(roboto), "KinCony B2");
download yaml file:
.txt   B2-HA-Tuya.txt (Size: 3.58 KB / Downloads: 181)
