Unresponsive KC868-A16
#11
good day sir, i will try to install KCS SOFTWARE first if my A16 board will response ok. then i will install the ESP home yaml after if successful. i will inform you sir. thank you.
ok
Good day sir,
i have tested the KCS firwmware for myA16 and the ethernet port was ok, i tested the output, but as soon as i uploaded the ESPHOME yaml file on my homeassistant the ETHERNET port turns OFF or it becomes disabled. i dont know why.
Can you check the pictures below, check if the CODE for the LAN Ethernet port is correct? I used the same code for the LAN before and it works.. Maybe there is a correct CODE for LAN Ethernet port.
Please check and advise sir.
Thank you
here is ESPhome config yaml for A16 board, you just directly to use:
  platform: ESP32
  sda: 4
  scl: 5
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
    address: 0x24
    address: 0x25
    address: 0x21
    address: 0x22
# Individual outputs
      pcf8574: pcf8574_hub_out_1
      # Use pin number 0
      # One of INPUT or OUTPUT
      mode: OUTPUT
      inverted: false
      pcf8574: pcf8574_hub_out_2
      # Use pin number 0
      mode: OUTPUT
      inverted: false
      pcf8574: pcf8574_hub_in_1
      # Use pin number 0
      inverted: false
      pcf8574: pcf8574_hub_in_2
      # Use pin number 0
      inverted: false
I bought new board KC868-A16 in version 1.6 and i want install KCS SOFTWARE V2.2.2 in this board according online guide, but I have the following errors.
Please help me.
before you download firmware, you should remove RF433MHz receiver module from your A16 PCB. can you take a photo of your working A16 PCB.
Now it's OK, thank you.
What's the easiest way to connect it with a home assistant?
if you want A16 integrate to home assistant, use by ESPHome is easiest.
4 Guest(s)
