Threads: 1
Добрый день!
Подскажите пожалуйста, приобрел у вас KC868-Server Ethernet WiFi CM4 + KC868-H32B Pro-2. По вашим видеоурокам собрал KC868-Server Ethernet Домашний помощник освещение, все работает. Как подключить к серверу KC868-Server надежный способ, проводным или MQTT какой лучше, чтобы Работала безотказно KC868-H32B Pro-2. Можете отправить послання. Спасибо!
Threads: 1,609
sorry, i don't understand your question, can you write in English?
Threads: 1
Good afternoon
Please tell me, I buy KC868-Server Ethernet WiFi CM4 and KC868-H32B Pro-2 from you. Based on your video tutorials, I assembled the KC868-Server Ethernet Home assistant, lighting everything works. How can i connect to the KC868-Server in a reliable way, wired or MQTT which is better, so that the KC868-H32B Pro-2 works flawlessly. Sorry, I am newbie!
Thank you!
Threads: 1,609
KC868-H32B Pro add to KC868-Server by MQTT via ethernet cable is better.
Threads: 1
Good evening! Do you have a link on how to do it? I have to write the code KC868-H32B Pro in mqtt.yaml where are the codes from KC868-Server written? Or create a new yaml file for KC868-H32B Pro?
Threads: 1
Good afternoon! Tell me please, is there a breaker installing the machine before the relay or after? In one video you put before the last video put after the relay.
Threads: 1,609
the new version we put breaker before. also it can work in behind relay.
Threads: 1
Threads: 1,609
do your KC868-Server's IP address is 192.168.101.4?
please upload your yaml file at here. (not photo)
