01-10-2024, 06:47 AM
firmware BIN file download with address 0x0:
voice-control_0x0.zip (Size: 116.47 KB / Downloads: 1,010)
arduino source code:
#include <Arduino.h>
#include <TuyaWifi.h>
TuyaWifi my_device;
/* Current LED status */
unsigned char led_state = 0;
int key_pin = 27;
/* Data point define */
#define DPID_SWITCH_1 1
#define DPID_SWITCH_2 2
#define DPID_SWITCH_3 3
#define DPID_SWITCH_4 4
#define DPID_SWITCH_5 5
#define DPID_SWITCH_6 6
#define DPID_SWITCH_7 113
#define DPID_SWITCH_8 114
#define DPID_SWITCH_9 115
#define DPID_SWITCH_10 116
#define DPID_SWITCH_11 117
#define DPID_SWITCH_12 118
#define DPID_SWITCH_13 119
#define DPID_SWITCH_14 120
#define DPID_SWITCH_15 121
#define DPID_SWITCH_16 122
#define DPID_SWITCH_17 123
#define DPID_SWITCH_18 124
#define DPID_SWITCH_19 125
#define DPID_SWITCH_20 126
#define DPID_SWITCH_21 127
#define DPID_SWITCH_22 128
#define DPID_SWITCH_23 129
#define DPID_SWITCH_24 130
#define DPID_SWITCH_25 131
#define DPID_SWITCH_26 132
#define DPID_SWITCH_27 133
#define DPID_SWITCH_28 134
#define DPID_SWITCH_29 135
#define DPID_SWITCH_30 136
#define DPID_SWITCH_31 137
#define DPID_SWITCH_32 138
#define LED_WiFi 26
#define LED_User 33
unsigned char switch_1_state = 0;
unsigned char switch_2_state = 0;
unsigned char switch_3_state = 0;
unsigned char switch_4_state = 0;
unsigned char switch_5_state = 0;
unsigned char switch_6_state = 0;
unsigned char switch_7_state = 0;
unsigned char switch_8_state = 0;
unsigned char switch_9_state = 0;
unsigned char switch_10_state = 0;
unsigned char switch_11_state = 0;
unsigned char switch_12_state = 0;
unsigned char switch_13_state = 0;
unsigned char switch_14_state = 0;
unsigned char switch_15_state = 0;
unsigned char switch_16_state = 0;
unsigned char switch_17_state = 0;
unsigned char switch_18_state = 0;
unsigned char switch_19_state = 0;
unsigned char switch_20_state = 0;
unsigned char switch_21_state = 0;
unsigned char switch_22_state = 0;
unsigned char switch_23_state = 0;
unsigned char switch_24_state = 0;
unsigned char switch_25_state = 0;
unsigned char switch_26_state = 0;
unsigned char switch_27_state = 0;
unsigned char switch_28_state = 0;
unsigned char switch_29_state = 0;
unsigned char switch_30_state = 0;
unsigned char switch_31_state = 0;
unsigned char switch_32_state = 0;
* dp type(TuyaDefs.h) : DP_TYPE_RAW, DP_TYPE_BOOL, DP_TYPE_VALUE, DP_TYPE_STRING, DP_TYPE_ENUM, DP_TYPE_BITMAP
unsigned char dp_array[][2] =
{DPID_SWITCH_1, DP_TYPE_BOOL},{DPID_SWITCH_2, DP_TYPE_BOOL},{DPID_SWITCH_3, DP_TYPE_BOOL},{DPID_SWITCH_4, DP_TYPE_BOOL},{DPID_SWITCH_5, DP_TYPE_BOOL},{DPID_SWITCH_6, DP_TYPE_BOOL},
{DPID_SWITCH_7, DP_TYPE_BOOL},{DPID_SWITCH_8, DP_TYPE_BOOL},{DPID_SWITCH_9, DP_TYPE_BOOL},{DPID_SWITCH_10, DP_TYPE_BOOL},{DPID_SWITCH_11, DP_TYPE_BOOL},{DPID_SWITCH_12, DP_TYPE_BOOL},
{DPID_SWITCH_13, DP_TYPE_BOOL},{DPID_SWITCH_14, DP_TYPE_BOOL},{DPID_SWITCH_15, DP_TYPE_BOOL},{DPID_SWITCH_16, DP_TYPE_BOOL},{DPID_SWITCH_17, DP_TYPE_BOOL},{DPID_SWITCH_18, DP_TYPE_BOOL},
{DPID_SWITCH_19, DP_TYPE_BOOL},{DPID_SWITCH_20, DP_TYPE_BOOL},{DPID_SWITCH_21, DP_TYPE_BOOL},{DPID_SWITCH_22, DP_TYPE_BOOL},{DPID_SWITCH_23, DP_TYPE_BOOL},{DPID_SWITCH_24, DP_TYPE_BOOL},
{DPID_SWITCH_25, DP_TYPE_BOOL},{DPID_SWITCH_26, DP_TYPE_BOOL},{DPID_SWITCH_27, DP_TYPE_BOOL},{DPID_SWITCH_28, DP_TYPE_BOOL},{DPID_SWITCH_29, DP_TYPE_BOOL},{DPID_SWITCH_30, DP_TYPE_BOOL},
{DPID_SWITCH_31, DP_TYPE_BOOL},{DPID_SWITCH_32, DP_TYPE_BOOL},
unsigned char pid[] = {"tsfqvoyi6pxqxq6o"};
/* last time */
unsigned long last_time = 0;
void setup()
// Serial with tuyawifi
Serial.begin(9600,SERIAL_8N1,14,13);
pinMode(LED_WiFi, OUTPUT);
digitalWrite(LED_WiFi, LOW);
pinMode(LED_User, OUTPUT);
digitalWrite(LED_User, LOW);
//Initialize networking keys.
my_device.init(pid, mcu_ver);
my_device.set_dp_cmd_total(dp_array, 1);
last_time = millis();
void loop()
my_device.uart_service();
//Enter the connection network mode when Pin7 is pressed.
delay(80);
if (led_state == LOW) {
led_state = HIGH;
} else {
led_state = LOW;
digitalWrite(LED_WiFi, led_state);
delay(10);
* @param {unsigned char} dpid
* @return {unsigned char}
switch(dpid) {
case DPID_SWITCH_1:
switch_1_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
//Status changes should be reported.
my_device.mcu_dp_update(DPID_SWITCH_1, switch_1_state, length);
break;
case DPID_SWITCH_2:
switch_2_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
my_device.mcu_dp_update(DPID_SWITCH_2, switch_2_state, length);
break;
case DPID_SWITCH_3:
switch_3_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
my_device.mcu_dp_update(DPID_SWITCH_3, switch_3_state, length);
break;
case DPID_SWITCH_4:
switch_4_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
my_device.mcu_dp_update(DPID_SWITCH_4, switch_4_state, length);
break;
case DPID_SWITCH_5:
switch_5_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
my_device.mcu_dp_update(DPID_SWITCH_5, switch_5_state, length);
break;
case DPID_SWITCH_6:
switch_6_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
my_device.mcu_dp_update(DPID_SWITCH_6, switch_6_state, length);
break;
case DPID_SWITCH_7:
switch_7_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
my_device.mcu_dp_update(DPID_SWITCH_7, switch_7_state, length);
break;
case DPID_SWITCH_8:
switch_8_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
my_device.mcu_dp_update(DPID_SWITCH_8, switch_8_state, length);
break;
case DPID_SWITCH_9:
switch_9_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
my_device.mcu_dp_update(DPID_SWITCH_9, switch_9_state, length);
break;
case DPID_SWITCH_10:
switch_10_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
my_device.mcu_dp_update(DPID_SWITCH_10, switch_10_state, length);
break;
case DPID_SWITCH_11:
switch_11_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
my_device.mcu_dp_update(DPID_SWITCH_11, switch_11_state, length);
break;
case DPID_SWITCH_12:
switch_12_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
my_device.mcu_dp_update(DPID_SWITCH_12, switch_12_state, length);
break;
case DPID_SWITCH_13:
switch_13_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
my_device.mcu_dp_update(DPID_SWITCH_13, switch_13_state, length);
break;
case DPID_SWITCH_14:
switch_14_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
my_device.mcu_dp_update(DPID_SWITCH_14, switch_14_state, length);
break;
case DPID_SWITCH_15:
switch_15_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
my_device.mcu_dp_update(DPID_SWITCH_15, switch_15_state, length);
break;
case DPID_SWITCH_16:
switch_16_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
my_device.mcu_dp_update(DPID_SWITCH_16, switch_16_state, length);
break;
case DPID_SWITCH_17:
switch_17_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
my_device.mcu_dp_update(DPID_SWITCH_17, switch_17_state, length);
break;
case DPID_SWITCH_18:
switch_18_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
my_device.mcu_dp_update(DPID_SWITCH_18, switch_18_state, length);
break;
case DPID_SWITCH_19:
switch_19_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
my_device.mcu_dp_update(DPID_SWITCH_19, switch_19_state, length);
break;
case DPID_SWITCH_20:
switch_20_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
my_device.mcu_dp_update(DPID_SWITCH_20, switch_20_state, length);
break;
case DPID_SWITCH_21:
switch_21_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
my_device.mcu_dp_update(DPID_SWITCH_21, switch_21_state, length);
break;
case DPID_SWITCH_22:
switch_22_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
my_device.mcu_dp_update(DPID_SWITCH_22, switch_22_state, length);
break;
case DPID_SWITCH_23:
switch_23_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
my_device.mcu_dp_update(DPID_SWITCH_23, switch_23_state, length);
break;
case DPID_SWITCH_24:
switch_24_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
my_device.mcu_dp_update(DPID_SWITCH_24, switch_24_state, length);
break;
case DPID_SWITCH_25:
switch_25_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
my_device.mcu_dp_update(DPID_SWITCH_25, switch_25_state, length);
break;
case DPID_SWITCH_26:
switch_26_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
my_device.mcu_dp_update(DPID_SWITCH_26, switch_26_state, length);
break;
case DPID_SWITCH_27:
switch_27_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
my_device.mcu_dp_update(DPID_SWITCH_27, switch_27_state, length);
break;
case DPID_SWITCH_28:
switch_28_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
my_device.mcu_dp_update(DPID_SWITCH_28, switch_28_state, length);
break;
case DPID_SWITCH_29:
switch_29_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
my_device.mcu_dp_update(DPID_SWITCH_29, switch_29_state, length);
break;
case DPID_SWITCH_30:
switch_30_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
my_device.mcu_dp_update(DPID_SWITCH_30, switch_30_state, length);
break;
case DPID_SWITCH_31:
switch_31_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
my_device.mcu_dp_update(DPID_SWITCH_31, switch_31_state, length);
break;
case DPID_SWITCH_32:
switch_32_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
my_device.mcu_dp_update(DPID_SWITCH_32, switch_32_state, length);
break;
default:break;
return TY_SUCCESS;
* @param {*}
* @return {*}
void dp_update_all(void)
my_device.mcu_dp_update(DPID_SWITCH_1, switch_1_state, 1);
my_device.mcu_dp_update(DPID_SWITCH_2, switch_2_state, 1);
my_device.mcu_dp_update(DPID_SWITCH_3, switch_3_state, 1);
my_device.mcu_dp_update(DPID_SWITCH_4, switch_4_state, 1);
my_device.mcu_dp_update(DPID_SWITCH_5, switch_5_state, 1);
my_device.mcu_dp_update(DPID_SWITCH_6, switch_6_state, 1);
my_device.mcu_dp_update(DPID_SWITCH_7, switch_7_state, 1);
my_device.mcu_dp_update(DPID_SWITCH_8, switch_8_state, 1);
my_device.mcu_dp_update(DPID_SWITCH_9, switch_9_state, 1);
my_device.mcu_dp_update(DPID_SWITCH_10, switch_10_state, 1);
my_device.mcu_dp_update(DPID_SWITCH_11, switch_11_state, 1);
my_device.mcu_dp_update(DPID_SWITCH_12, switch_12_state, 1);
my_device.mcu_dp_update(DPID_SWITCH_13, switch_13_state, 1);
my_device.mcu_dp_update(DPID_SWITCH_14, switch_14_state, 1);
my_device.mcu_dp_update(DPID_SWITCH_15, switch_15_state, 1);
my_device.mcu_dp_update(DPID_SWITCH_16, switch_16_state, 1);
my_device.mcu_dp_update(DPID_SWITCH_17, switch_17_state, 1);
my_device.mcu_dp_update(DPID_SWITCH_18, switch_18_state, 1);
my_device.mcu_dp_update(DPID_SWITCH_19, switch_19_state, 1);
my_device.mcu_dp_update(DPID_SWITCH_20, switch_20_state, 1);
my_device.mcu_dp_update(DPID_SWITCH_21, switch_21_state, 1);
my_device.mcu_dp_update(DPID_SWITCH_22, switch_22_state, 1);
my_device.mcu_dp_update(DPID_SWITCH_23, switch_23_state, 1);
my_device.mcu_dp_update(DPID_SWITCH_24, switch_24_state, 1);
my_device.mcu_dp_update(DPID_SWITCH_25, switch_25_state, 1);
my_device.mcu_dp_update(DPID_SWITCH_26, switch_26_state, 1);
my_device.mcu_dp_update(DPID_SWITCH_27, switch_27_state, 1);
my_device.mcu_dp_update(DPID_SWITCH_28, switch_28_state, 1);
my_device.mcu_dp_update(DPID_SWITCH_29, switch_29_state, 1);
my_device.mcu_dp_update(DPID_SWITCH_30, switch_30_state, 1);
my_device.mcu_dp_update(DPID_SWITCH_31, switch_31_state, 1);
my_device.mcu_dp_update(DPID_SWITCH_32, switch_32_state, 1);
