Threads: 0
Hi there,
I have two questions:
- Is the PC Software also available for Linux?
- Is it possible to change the Baudrate of the KC868-HA-V2. I have other stuff on my RS485-Bus which needs different Baudrate.
Thanks very much in advance.
Threads: 0
Hi there again,
ok, I found out how to change the baudrate.
I changed it to 57600 baud without parity. That worked.
But I need 57600 baud with parity even. It seems that setting parity doesn't work. I tried it with even and odd.
Could you please check that.
My firmware version is V200
Martin
Threads: 1,604
how do you use HAv2, HAv2 connect to KinCony's relay board? or HAv2 connect to raspberry pi directly?
Threads: 1,604
KC868-AP not support HA board.
Threads: 1,604
HAv2 support change baudrate by PC software.
Threads: 1,604
do you means, the partity only work for "NONE"?
