KinCony ESP32-S3 Core Board released
We have designed ESP32-S3 Core Board - KinCony S3. it's mini PCB, support install by DIN RAIL. it use ESP32-S3-WROOM-1U N16R8 chip. small PCB with RS485, I2C bus, 1-wire, analog input ports. analog input port can use for VOLTAGE / CURRENT signal set by jumper. It have ethernet port, also have SIM7600 4G module and RF 433MHz reciever interface. It can use for smart home IoT project use by home assistant, you can config ymal by ESPHome. S3 also support arduino IDE / MicroPython / ESP-IDF development tool.
[Image: S3-1.jpg]
PCB size: 80mm*65mm
Power supply: DC 9-24V
[Image: S3-schematic.jpg]
I just purchased this product but I am having difficulty figuring out how to flash the program. I would appreciated it if you inform me.
1. if you want to use by home assistant, you can config by ESPHome.
2. if you want to write your own code, such as arduino IDE, you can write code and download to ESP32-S3 chip by USB-C cable.
