ESPHome DAC output DC 0-10V
Is it possible to use outputs V-OUT1-8 to control a car charger that requires a control DAC output DC 0-10V?
If possible, I would need a KC868-A8M ESP32 I/O pin define.
I assume that the next work will be similar to the post for KC868-AP / ADR: https://www.kincony.com/forum/showthread.php?tid=2889
KC868-A8M is mosfet output, not use for 0-10v output. if you want use 0-10V output, you can use KC868-A4S or other model.
here is ESP32 IO pin define for KC868-A8M: https://www.kincony.com/forum/showthread.php?tid=2790
