07-31-2024, 09:14 AM
I've installed a KC868-a16 and used the 12v powersupply delivered by Kincony. For output's I use a seperate 24v power supply. The board is flashed by using ESPHOME+HomeAssistant.
5 inputs+outputs are in use.
The problem occurs when using the default code (by Kincony) and when I use a modified version.
The problem:
- When output 1,2,3,4 switched on, the corresponding LED's switch on and my relays switch on.
- When switching output 5 on, all LED's switch off, except5. all relays stay on, but cannot be controlled by switching off the output (1,2,3,4).
the same issue occurs when I switch 1,2,4,5 on. Then output 3 starts the problem.
my thoughts:
- I2C adresses seem to be ok (v1.6 board)
- no library installed
Please let me know
The problem:
my thoughts:
Please let me know
