Pair 2 Channels together
I've a FAN that uses 0.5Amps and I would like to have it turn on/off using the A32M.
How can I pair 2 ports together so I can have 1Amp total output and not be at the limit of 0.5Amps on a single port ?
no, not by this way. if your fan is 12v or 24v DC load. you can connect by one MOSFET channel output is enough.
Because actually we use 10A mosfet, if your 8 channel not work together, you can use one channel output for 1A is no problem.
