08-30-2024, 06:23 AM
new configuration.yaml file for home assistant MQTT. this file fixed linear issue.
yaml file download:
mqtt-kc868-d16-home-assistant-16-channel-config.txt (Size: 12.37 KB / Downloads: 673)
linedddar issuedd
mqtt:
light:
- name: D16-1
unique_id: D16-1
schema: template
command_topic: "dimmer/be06d3fd6311b55a970bba37/set"
state_topic: "dimmer/be06d3fd6311b55a970bba37/state"
command_on_template: >
{%- if brightness is defined -%}
{"dimmer1":{"value":{{ (brightness / 255 * 99) | int }}}
{%- else -%}
{"dimmer1":{"value":99}}
{%- endif -%}
command_off_template: '{"dimmer1":{"value":0}}'
state_template: >
{%- if value_json.dimmer1.value == 0 -%}
off
{%- else -%}
on
{%- endif -%}
brightness_template: >
{%- if value_json.dimmer1.value is defined -%}
{{ (value_json.dimmer1.value / 99 * 255) | int }}
{%- else -%}
{%- endif -%}
- name: D16-2
unique_id: D16-2
schema: template
{"dimmer2":{"value":{{ (brightness / 255 * 99) | int }}}
{%- else -%}
{"dimmer2":{"value":99}}
{%- endif -%}
command_off_template: '{"dimmer2":{"value":0}}'
state_template: >
{%- if value_json.dimmer2.value == 0 -%}
off
{%- else -%}
on
{%- endif -%}
{%- if value_json.dimmer2.value is defined -%}
{{ (value_json.dimmer2.value / 99 * 255) | int }}
{%- else -%}
{%- endif -%}
- name: D16-3
unique_id: D16-3
schema: template
{"dimmer3":{"value":{{ (brightness / 255 * 99) | int }}}
{%- else -%}
{"dimmer3":{"value":99}}
{%- endif -%}
command_off_template: '{"dimmer3":{"value":0}}'
state_template: >
{%- if value_json.dimmer3.value == 0 -%}
off
{%- else -%}
on
{%- endif -%}
{%- if value_json.dimmer3.value is defined -%}
{{ (value_json.dimmer3.value / 99 * 255) | int }}
{%- else -%}
{%- endif -%}
- name: D16-4
unique_id: D16-4
schema: template
{"dimmer4":{"value":{{ (brightness / 255 * 99) | int }}}
{%- else -%}
{"dimmer4":{"value":99}}
{%- endif -%}
command_off_template: '{"dimmer4":{"value":0}}'
state_template: >
{%- if value_json.dimmer4.value == 0 -%}
off
{%- else -%}
on
{%- endif -%}
{%- if value_json.dimmer4.value is defined -%}
{{ (value_json.dimmer4.value / 99 * 255) | int }}
{%- else -%}
{%- endif -%}
- name: D16-5
unique_id: D16-5
schema: template
{"dimmer5":{"value":{{ (brightness / 255 * 99) | int }}}
{%- else -%}
{"dimmer5":{"value":99}}
{%- endif -%}
command_off_template: '{"dimmer5":{"value":0}}'
state_template: >
{%- if value_json.dimmer5.value == 0 -%}
off
{%- else -%}
on
{%- endif -%}
{%- if value_json.dimmer5.value is defined -%}
{{ (value_json.dimmer5.value / 99 * 255) | int }}
{%- else -%}
{%- endif -%}
- name: D16-6
unique_id: D16-6
schema: template
{"dimmer6":{"value":{{ (brightness / 255 * 99) | int }}}
{%- else -%}
{"dimmer6":{"value":99}}
{%- endif -%}
command_off_template: '{"dimmer6":{"value":0}}'
state_template: >
{%- if value_json.dimmer6.value == 0 -%}
off
{%- else -%}
on
{%- endif -%}
{%- if value_json.dimmer6.value is defined -%}
{{ (value_json.dimmer6.value / 99 * 255) | int }}
{%- else -%}
{%- endif -%}
- name: D16-7
unique_id: D16-7
schema: template
{"dimmer7":{"value":{{ (brightness / 255 * 99) | int }}}
{%- else -%}
{"dimmer7":{"value":99}}
{%- endif -%}
command_off_template: '{"dimmer7":{"value":0}}'
state_template: >
{%- if value_json.dimmer7.value == 0 -%}
off
{%- else -%}
on
{%- endif -%}
{%- if value_json.dimmer7.value is defined -%}
{{ (value_json.dimmer7.value / 99 * 255) | int }}
{%- else -%}
{%- endif -%}
- name: D16-8
unique_id: D16-8
schema: template
{"dimmer8":{"value":{{ (brightness / 255 * 99) | int }}}
{%- else -%}
{"dimmer8":{"value":99}}
{%- endif -%}
command_off_template: '{"dimmer8":{"value":0}}'
state_template: >
{%- if value_json.dimmer8.value == 0 -%}
off
{%- else -%}
on
{%- endif -%}
{%- if value_json.dimmer8.value is defined -%}
{{ (value_json.dimmer8.value / 99 * 255) | int }}
{%- else -%}
{%- endif -%}
- name: D16-9
unique_id: D16-9
schema: template
{"dimmer9":{"value":{{ (brightness / 255 * 99) | int }}}
{%- else -%}
{"dimmer9":{"value":99}}
{%- endif -%}
command_off_template: '{"dimmer9":{"value":0}}'
state_template: >
{%- if value_json.dimmer9.value == 0 -%}
off
{%- else -%}
on
{%- endif -%}
{%- if value_json.dimmer9.value is defined -%}
{{ (value_json.dimmer9.value / 99 * 255) | int }}
{%- else -%}
{%- endif -%}
- name: D16-10
unique_id: D16-10
schema: template
{"dimmer10":{"value":{{ (brightness / 255 * 99) | int }}}
{%- else -%}
{"dimmer10":{"value":99}}
{%- endif -%}
command_off_template: '{"dimmer10":{"value":0}}'
state_template: >
{%- if value_json.dimmer10.value == 0 -%}
off
{%- else -%}
on
{%- endif -%}
{%- if value_json.dimmer10.value is defined -%}
{{ (value_json.dimmer10.value / 99 * 255) | int }}
{%- else -%}
{%- endif -%}
- name: D16-11
unique_id: D16-11
schema: template
{"dimmer11":{"value":{{ (brightness / 255 * 99) | int }}}
{%- else -%}
{"dimmer11":{"value":99}}
{%- endif -%}
command_off_template: '{"dimmer11":{"value":0}}'
state_template: >
{%- if value_json.dimmer11.value == 0 -%}
off
{%- else -%}
on
{%- endif -%}
{%- if value_json.dimmer11.value is defined -%}
{{ (value_json.dimmer11.value / 99 * 255) | int }}
{%- else -%}
{%- endif -%}
- name: D16-12
unique_id: D16-12
schema: template
{"dimmer12":{"value":{{ (brightness / 255 * 99) | int }}}
{%- else -%}
{"dimmer12":{"value":99}}
{%- endif -%}
command_off_template: '{"dimmer12":{"value":0}}'
state_template: >
{%- if value_json.dimmer12.value == 0 -%}
off
{%- else -%}
on
{%- endif -%}
{%- if value_json.dimmer12.value is defined -%}
{{ (value_json.dimmer12.value / 99 * 255) | int }}
{%- else -%}
{%- endif -%}
- name: D16-13
unique_id: D16-13
schema: template
{"dimmer13":{"value":{{ (brightness / 255 * 99) | int }}}
{%- else -%}
{"dimmer13":{"value":99}}
{%- endif -%}
command_off_template: '{"dimmer13":{"value":0}}'
state_template: >
{%- if value_json.dimmer13.value == 0 -%}
off
{%- else -%}
on
{%- endif -%}
{%- if value_json.dimmer13.value is defined -%}
{{ (value_json.dimmer13.value / 99 * 255) | int }}
{%- else -%}
{%- endif -%}
- name: D16-14
unique_id: D16-14
schema: template
{"dimmer14":{"value":{{ (brightness / 255 * 99) | int }}}
{%- else -%}
{"dimmer14":{"value":99}}
{%- endif -%}
command_off_template: '{"dimmer14":{"value":0}}'
state_template: >
{%- if value_json.dimmer14.value == 0 -%}
off
{%- else -%}
on
{%- endif -%}
{%- if value_json.dimmer14.value is defined -%}
{{ (value_json.dimmer14.value / 99 * 255) | int }}
{%- else -%}
{%- endif -%}
- name: D16-15
unique_id: D16-15
schema: template
{"dimmer15":{"value":{{ (brightness / 255 * 99) | int }}}
{%- else -%}
{"dimmer15":{"value":99}}
{%- endif -%}
command_off_template: '{"dimmer15":{"value":0}}'
state_template: >
{%- if value_json.dimmer15.value == 0 -%}
off
{%- else -%}
on
{%- endif -%}
{%- if value_json.dimmer15.value is defined -%}
{{ (value_json.dimmer15.value / 99 * 255) | int }}
{%- else -%}
{%- endif -%}
- name: D16-16
unique_id: D16-16
schema: template
{"dimmer16":{"value":{{ (brightness / 255 * 99) | int }}}
{%- else -%}
{"dimmer16":{"value":99}}
{%- endif -%}
command_off_template: '{"dimmer16":{"value":0}}'
state_template: >
{%- if value_json.dimmer16.value == 0 -%}
off
{%- else -%}
on
{%- endif -%}
{%- if value_json.dimmer16.value is defined -%}
{{ (value_json.dimmer16.value / 99 * 255) | int }}
{%- else -%}
{%- endif -%}yaml file download:
linedddar issuedd
