"KCS" v2.2.4 firmware BIN file download
How to download and use, online guide: https://www.kincony.com/esp32-kcsv2-firmware.html
v2.2.4 improment:
1. replaced new DHT sensor's driver.
2. fixed MQTT protocol format bug.
.zip   KCS_KC868_AIO_V2.2.4.zip (Size: 805.72 KB / Downloads: 877)
.zip   KCS_KC868_AK_V2.2.4.zip (Size: 766.78 KB / Downloads: 875)
.zip   KCS_KC868_AM_V2.2.4.zip (Size: 781.63 KB / Downloads: 851)
.zip   KCS_KC868_AP_V2.2.4.zip (Size: 784.23 KB / Downloads: 854)
.zip   KCS_KC868_ASR_V2.2.4.zip (Size: 761.11 KB / Downloads: 830)
.zip   KCS_KC868_E16S_V2.2.4.zip (Size: 790.79 KB / Downloads: 853)
.zip   KCS_KC868_UAIR_V2.2.4.zip (Size: 767.67 KB / Downloads: 848)
.zip   KCS_KC868_A2_V2.2.4.zip (Size: 794.6 KB / Downloads: 825)
.zip   KCS_KC868_A4_V2.2.4.zip (Size: 781.71 KB / Downloads: 956)
.zip   KCS_KC868_A4S_V2.2.4.zip (Size: 805.34 KB / Downloads: 832)
.zip   KCS_KC868_A6_V2.2.4.zip (Size: 779.79 KB / Downloads: 946)
.zip   KCS_KC868_A8_V2.2.4.zip (Size: 788.5 KB / Downloads: 994)
.zip   KCS_KC868_A8M_V2.2.4.zip (Size: 804.71 KB / Downloads: 860)
.zip   KCS_KC868_A8S_V2.2.4.zip (Size: 806.39 KB / Downloads: 905)
.zip   KCS_KC868_A16_V2.2.4.zip (Size: 795.95 KB / Downloads: 1,050)
.zip   KCS_KC868_A16S_V2.2.4.zip (Size: 806.61 KB / Downloads: 905)
.zip   KCS_KC868_A32_V2.2.4.zip (Size: 786.12 KB / Downloads: 943)
.zip   KCS_KC868_A32M_V2.2.4.zip (Size: 804.14 KB / Downloads: 927)
.zip   KCS_KC868_A64_V2.2.4.zip (Size: 786.21 KB / Downloads: 894)
.zip   KCS_KC868_A128_V2.2.4.zip (Size: 786.33 KB / Downloads: 804)
.zip   KCS_KC868_AG_V2.2.4.zip (Size: 764.49 KB / Downloads: 873)
.zip   KCS_KC868_AI_V2.2.4.zip (Size: 788.72 KB / Downloads: 901)
(09-04-2024, 11:32 PM)admin Wrote: Here is "KCS" firmware for KinCony KC868-A series (ESP32) board.
v2.2.4 improment:
Is it possible to know more details on "MQTT Protocol format bug" ?
Missing comma
(10-03-2024, 03:58 AM)admin Wrote: Missing comma
I think it's an extra comma Tongue I see what you're talking about I've had to use a modifier on nodered to fix it.
When are you guys going to enable firmware update via the HTTP page ? Having to use a USB cable is not optimal
maybe in furture will design a new way to update firmware.
Please check the firmware to A32M controller,to correct output number and activate inter lock.
Hi, I installed V2.2.4 firmware n A6 board. I can see all inputs and outputs are working in monitior web page. However, When I short Digital inputs 1-6 with ground, the relays are not turning ON. Could you please help fixing this issue?
(10-10-2024, 07:15 PM)enochjason Wrote: Hi, I installed V2.2.4 firmware n A6 board. I can see all inputs and outputs are working in monitior web page. However, When I short Digital inputs 1-6 with ground, the relays are not turning ON. Could you please help fixing this issue?
it's not a issue. you should create IFTTT command on "IFTTT" webpage, let INPUT trigger with OUTPUT. please see online guide at here: https://www.kincony.com/esp32-kcsv2-firmware.html
(10-08-2024, 10:35 AM)yasin Wrote: Please check the firmware to A32M controller,to correct output number and activate inter lock.
updated new firmware at here: https://www.kincony.com/forum/showthread.php?tid=6870
