how to use AS ESP32-S3 voice assistant in home assistant
Set Up Voice Assist Pipeline
To set up voice assistant, we would need two components to create the Voice Assist pipeline in Home Assistant.
Whisper: For speech-to-text
Piper: For text-to-speech
1: Whisper Addon
2: Piper Addon
3: And finally the entire Voice Assist pipeline.
You don't need to set up the Wake Word addon, as we will use the on-device Wake Word detection with the Micro Wake Word framework
So make sure to watch it and set up the Voice Assist pipeline
ESPHome - add device - create new device called AS:
copy and paste KinCony AS yaml file:
  friendly_name: AS
  platformio_options:
    board_build.flash_mode: dio
  on_boot:
    - light.turn_on:
        blue: 100%
        brightness: 60%
        effect: fast pulse
  board: esp32-s3-devkitc-1
    type: esp-idf
    sdkconfig_options:
      CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: "y"
      CONFIG_ESP32S3_DATA_CACHE_64KB: "y"
      CONFIG_ESP32S3_DATA_CACHE_LINE_64B: "y"
      CONFIG_AUDIO_BOARD_CUSTOM: "y"
psram:
  mode: octal  # quad for N8R2 and octal for N16R8
  speed: 80MHz
  encryption:
    key: "TFpb+pBAvQIS1MVwaA7EoJ2DkpWE+79UvVro7yMyGdU="
  on_client_connected:
        then:
          - delay: 50ms
          - light.turn_off: led_ww
          - micro_wake_word.start:
  on_client_disconnected:
        then:
          - voice_assistant.stop:
ota:
  - platform: esphome
    password: "1245211a05eef56614a2ef5a3f3e971c"
wifi:
  ssid: "KinCony"
  password: "a12345678"
  ap:
    ssid: "Esp32-S3-Wake-Word"
    password: "LJfUrdJk3svP"
captive_portal:
button:
  - platform: restart
  - platform: template
    optimistic: true
    on_turn_on:
      - micro_wake_word.stop:
      - light.turn_on:
          red: 100%
          green: 0%
          blue: 0%
          brightness: 60%
          effect: fast pulse
      - delay: 2s
      - light.turn_off:
      - light.turn_on:
          red: 100%
          green: 0%
          blue: 0%
          brightness: 30%
    on_turn_off:
      - light.turn_on:
          red: 0%
          green: 100%
          blue: 0%
          brightness: 60%
          effect: fast pulse
      - delay: 2s
      - light.turn_off:
light:
  - platform: esp32_rmt_led_strip
    rgb_order: GRB
    pin: GPIO16
    num_leds: 1
    rmt_channel: 0
    chipset: ws2812
    name: "on board light"
    effects:
      - pulse:
      - pulse:
          transition_length: 0.5s
          update_interval: 0.5s
          min_brightness: 0%
          max_brightness: 100%
# Audio and Voice Assistant Config
i2s_audio:
  - id: i2s_in
    i2s_lrclk_pin: GPIO3  #WS
    i2s_bclk_pin: GPIO2 #SCK
  - id: i2s_speaker
    i2s_lrclk_pin: GPIO6  #LRC
    i2s_bclk_pin: GPIO7 #BLCK
microphone:
  - platform: i2s_audio
    adc_type: external
    i2s_din_pin: GPIO4 #SD pin on the INMP441
    channel: left
    pdm: false
    i2s_audio_id: i2s_in
    bits_per_sample: 32 bit
speaker:
    platform: i2s_audio
    i2s_audio_id: i2s_speaker
    dac_type: external
    i2s_dout_pin: GPIO8   #  DIN Pin of the MAX98357A Audio Amplifier
    channel: mono
micro_wake_word:
  on_wake_word_detected:
    # then:
    - voice_assistant.start:
        wake_word: !lambda return wake_word;
    - light.turn_on:
        red: 30%
        green: 30%
        blue: 70%
        brightness: 60%
        effect: fast pulse
  models:
    - model: hey_jarvis
voice_assistant:
  microphone: va_mic
  noise_suppression_level: 2.0
  volume_multiplier: 4.0
  speaker: va_speaker
  on_stt_end:
       then:
  on_error:
  on_end:
        then:
          - wait_until:
              not:
                voice_assistant.is_running:
Note: replace wifi router's ssid and password by yourself.
yaml file download from: https://www.kincony.com/forum/showthread.php?tid=6890
now connect AS to your Server16's USB port (raspberry pi or your own server)
click right top windows "install" button, then will show you install way, chose "Plug into the computer running ESPHome Dashboard" item
click "USB=JTAG" option that detected.
ESPHome begin compile and download firmware:
now you will find the AS device discovered on "setting" - "device webpage". Just click "CONFIGURE" button, assign a room to the device.
AS is ready.
if you speak "hey jarvis" command, voice assistant will show "listening", then you can say, such as "turn on light", "turn off light". just say the name of your device.
So far so good. I have everything up and running. I'm looking for some advice to improve.
1. Can I get the light to stay on while waiting for wake-word and then it changes and flashes while waiting for the person to stop speaking?
2. Is there a way to have volume control via the voice?
3. Is there a way to interrupt the assistant during long periods of responses. I have ollama as my assistant and sometimes I dont want to hear the responses all the time.
point 1 and point 2 can config by esphome.
I'm really loving this product and trying things with Yaml to get the features I want. I need some help if anyone can
I am adding options to always show the light and change colors and pulse and I want a way to control volume from Home assistant interface.  I am close but its all not working.
I also have a bug that if I want to set colors in home assistant interface, they do not align with the colors showing on device.
the attached image you can see I have purple selected but the device shows blue
Oh 1 more thing I wanted to add a ding.wav but could not see how to add a file any help would be great there was well
This is my Yaml
  friendly_name: SARAH
  platformio_options:
  on_boot:
    - light.turn_on:
        blue: 100%
        brightness: 60%
        effect: fast pulse
    type: esp-idf
    sdkconfig_options:
psram:
  speed: 80MHz
  encryption:
    key: "************************************"
        then:
          - delay: 50ms
        then:
ota:
  - platform: esphome
    password: "*******************************"
wifi:
  ssid: "My-SSID"
  password: "***********************"
  ap:
    password: "********************"
captive_portal:
button:
  - platform: restart
globals:
  - id: current_volume
    type: float
    initial_value: '4.0'
number:
    optimistic: true
    min_value: 0.5
    max_value: 10.0
    step: 0.5
    restore_value: true
    initial_value: 4.0
    mode: slider
    set_action:
      - lambda: |-
          id(va).set_volume_multiplier(x);
    update_interval: 60s
    optimistic: true
    on_turn_on:
      - light.turn_on:
          red: 100%
          green: 0%
          blue: 0%
          brightness: 60%
          effect: fast pulse
      - delay: 2s
      - light.turn_off:
      - light.turn_on:
          red: 100%
          green: 0%
          blue: 0%
          brightness: 30%
    on_turn_off:
      - light.turn_on:
          red: 0%
          green: 100%
          blue: 0%
          brightness: 60%
          effect: fast pulse
      - delay: 2s
      - light.turn_off:
light:
    rgb_order: GRB
    pin: GPIO16
    num_leds: 1
    rmt_channel: 0
    chipset: ws2812
    effects:
      - pulse:
      - pulse:
          min_brightness: 0%
i2s_audio:
  - id: i2s_in
  - id: i2s_speaker
microphone:
    adc_type: external
    channel: left
    pdm: false
speaker:
    platform: i2s_audio
    dac_type: external
    channel: mono
micro_wake_word:
    # then:
    - light.turn_on:
        red: 30%
        green: 30%
        blue: 70%
        brightness: 60%
        effect: fast pulse
  models:
    - model: hey_jarvis
voice_assistant:
  microphone: va_mic
  speaker: va_speaker
  on_stt_end:
      then:
        - light.turn_on:
            red: 30%
            green: 30%
            blue: 70%
            brightness: 60%
            effect: none
  on_error:
  on_end:
        then:
          - light.turn_on:
              red: 30%
              green: 30%
              blue: 70%
              brightness: 60%
              effect: none
          - wait_until:
              not:
about the color, this line:
rgb_order: GRB
you can test with different mode:
Valid values are RGB, RBG, GRB, GBR, BRG and BGR. Defaults to RGB.
there is one mode is correct.
(12-07-2024, 12:09 AM)admin Wrote: about the color, this line:
rgb_order: GRB
Yes, I should have started there, If I use RGB that matches the color!
Any idea how to get the volume to slider I am making to change the volume on the device?  And if there is a way to upload a small .wav file to have it make a ding when enabled?
[Image: attachment.php?aid=6583]
see here in details: https://esphome.io/components/speaker/index.html
Also just beginning with ESP and find it hard to follow. So keep on reading Big Grin like the idea for volume control. Is there also a way to use the speaker to play media to it? I like to use bought leds so i flash it a second time and change gpio en leaf the RGB. There must be a beter way
sure, you can use media player component in ESPHome.
(12-08-2024, 11:33 AM)eyevisions Wrote: Also just beginning with ESP and find it hard to follow. So keep on reading Big Grin like the idea for volume control. Is there also a way to use the speaker to play media to it? I like to use bought leds so i flash it a second time and change gpio en leaf the RGB. There must be a beter way
I will be adding that to yaml, once i get the volume working properly its close but something is still off
