12-10-2024, 11:29 PM
just recently found about your Boards and luckily there is also some Loxone integration options available right from the producer. Great!
I would like to double check which parts / boards should I order to integrate with Loxone.
Loxone (master) <-> Kincony boads (Slave)
Eventually MQTT,UDP or Tasmota system would be also fine to integrate with Loxone (as i have already few devices working)
Here is the list what I would like to have:
KC868-E16S
Some of those features should be possible via
KC868-E16S
or KC868-E16T (not sure what is the difference, + Tuya support feature?)
In case there is newer / more suitable board, please let me know
Thanks!
KC868-E16S
- Preferably via LAN Cable (due to stability and latency)
- 12-16x Relays to operate 230v devices. Relays should be easily replaceable as on KC-868-E16 boards
- few DI for Digital Buttons, Impulse meter / Power consumption
KC868-E16S (not sure if 1-wire is there, but I see some I2C Extender on board - 1-wire for Temperature / Humidity sensor
- I2C support for SHT31 sensors or SCD30 (temp/hum/co2)
Probably some additional board to get AO ports - 2-3x AO 0-10v controller for FANs
KC868-E16S
Thanks!
![[Image: S5202fbdb63b4424fbb9dacdd36da83c3i.jpg]](https://ae01.alicdn.com/kf/S5202fbdb63b4424fbb9dacdd36da83c3i.jpg)
