H32L - home assistant
#11
the two H32L units are connected with https://it.aliexpress.com/i/1005004536942197.html
with tuya everything works perfectly, is it possible to bring to home assistant?
https://community.home-assistant.io/t/32...h32/155647
HI,
Is this the procedure for integrating h32L?
https://www.kincony.com/home-assistant-r...odule.html
I'm not very knowledgeable about programming, isn't there a plug-in for home assistant?
in any case, it is stable and reliable once brought up ha?
if you MUST want to use H32L with HA, you can see this way.
But we really not suggest to use H32L with HA.
I should...I have two H32L complete with two long range extensions and two esp tuya modules...I've invested some money, I don't want to have to change everything.
however, I would like the system to be STABLE.
if you want use HA, suggest replace with H32B Pro controller, that will stable. H32L not stable for HA.
to replace my h32Ls the expense would be 460+ dollars...unfortunately this is not a viable option.
I don't understand why from home assistant I only see 4 h32L channels. and they work well. I just wish I could see all 32 of them
I brought with tuya local
this is the screen "tuya developer platform"
H32B Pro (two units) are properly seen.
how can I bring them to home hassistant?
i said: i have not used integrate by tuya platform, you can post your question to home assistant community. Maybe someone can help you.
(12-28-2024, 11:49 PM)admin Wrote: i said: i have not used integrate by tuya platform, you can post your question to home assistant community. Maybe someone can help you.
SOLVED:
I imported via local tuya and added all the entities "manually". I see all 32 outputs and 6 inputs. If anyone needs, please write here
