the ESPHome yaml demo made for KinCony KC868-A8S relay board. Actually you can use for any KinCony SIM7600 relay board, just replace 4G module's TXD,RXD define.
here is ESPHome yaml demo:
platform: ESP32
sda: 4
scl: 5
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
address: 0x24
address: 0x22
# Individual outputs
pcf8574: pcf8574_hub_out_1
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
interlock: [relay6]
number: 4
mode: OUTPUT
interlock: [relay5]
number: 5
mode: OUTPUT
interlock: [relay8]
number: 6
mode: OUTPUT
interlock: [relay7]
number: 7
mode: OUTPUT
# UART configuration for SIM7600E
uart:
tx_pin: GPIO13
rx_pin: GPIO15
baud_rate: 115200
debug:
direction: BOTH
dummy_receiver: true
after:
timeout: 10ms
sequence:
on_press:
then:
- uart.write:
data: "ATD15381188302;\r\n" # Replace with the phone number you want to dial
pcf8574: pcf8574_hub_in_1
on_press:
then:
- switch.toggle: light2
on_press:
then:
- switch.toggle: light3
on_press:
then:
- switch.toggle: light4
on_press:
then:
- switch.toggle: relay5
number: 4
on_press:
then:
- switch.toggle: relay6
number: 5
on_press:
then:
- switch.toggle: relay7
number: 6
on_press:
then:
- switch.toggle: relay8
number: 7
web_server:
port: 80
KC868-A8S-HA-INPUT-SIM7600-CALL.txt (Size: 4.03 KB / Downloads: 655)
