KC868-A6 tasmota digital/analog input integration to Loxone
can you provide info how to integrate http commands for loxone to read digital and analog inputs via tasmota firmware?
Or how we can read DI/AI inputs from this board in the loxone?
Can we use e.g. UDP commands somehow in the tasmota and loxone?
Thanks
KCS v3 firmware can use for Loxone UDP command integration. such as KinCony A32Pro, F16,F24,B16M controller.
here is details: https://www.kincony.com/forum/showthread.php?tid=7264
(01-15-2025, 11:25 PM)admin Wrote: KCS v3 firmware can use for Loxone UDP command integration. such as KinCony A32Pro, F16,F24,B16M controller.
Thanks for your answer, unfortunately I don´t have any A32Pro nor F16,F24 hardware version which supports KCS v3 firm.
I have KS868-A6 board, so my intention is integrate this stuff.
so as I understand well, there is no way how to communicate with this board via UDP protocol or tasmota firmware? - that means not possible to read digital/analog state of signals?
Thanks
i have not tested with tasmota + UDP command, we will release KC868-A6v3 PCB soon, it can support Loxone by UDP directly.
