"KCS" v2.2.10 firmware BIN file download
#11
will it be possible to export and import IFTTT in the future??
(01-16-2025, 02:51 PM)Poczwara13 Wrote: Hello,
will design this in future.
I'm having problems flashing the KCS_KC868_A16_V2.2.10.bin to a newly purchased KC868-A16.
I did everything according to her instructions.
The USB interface is OK, the transfer shows a series of progress points - but they don't end.
If I press the download button an error message appears. That means my PC somehow communicates with your card.
I tried different Windows 7, 10 and 11 PCs, no difference.
I suspect a defective ESP.
you should chose chip type "ESP32", NOT "ESP32-S3".
Why is the firmware version 2.2.10 not provided for the A24 card which unfortunately remained only at version 2.2.2?
(01-19-2025, 08:22 PM)davidecioi Wrote: Why is the firmware version 2.2.10 not provided for the A24 card which unfortunately remained only at version 2.2.2?
yes, A24 not updated.
In the distant future?? Is it a matter of days or month?? I ask because I have control based on IFTTT to prepare, which would be a great convenience.
it will be a long time, not easy, not soon. will design based on KCS v3.
The "auto send ADC values" ​​function is not working in KCS V2.2.10!
With this function active I should receive messages in my MQTT every 5 seconds, this is not happening!
I am using the K868-A4 board.
(01-23-2025, 08:40 PM)csacomani Wrote: The "auto send ADC values" ​​function is not working in KCS V2.2.10!
do you have set the "threshold" for every ADC channel, just click "gear" ico to set.
