KinCony ALR ESP32-S3 LoRa SX1278 Gateway released
We have designed ESP32 LoRa SX1278 Gateway - KinCony ALR. It support install into waterproof box. it use ESP32-S3-WROOM-1U N16R8 chip. small PCB with relay,SSD1306 LCD, 4 channel analog input, digital input, i2c bus extender, 1-wire GPIO, SX1278 LoRa module, DIP switch set for LoRa address.It can use for smart home IoT project use by home assistant. ESP32-S3 also support arduino IDE / MicroPython / ESP-IDF development tool.
[Image: ESP32-LoRa-1.jpg]
[Image: ALR_diagram.jpg]
Hardware resource:
Power supply: DC9-24V
USB-C: download firmware
Buttons: ESP32 Reset and Download
SX1278 LoRa module
Relay: MAX Load AC250v10A COM,NO,NC
SSD1306 i2c LCD
8bit DIP switch: set LoRa device address
Analog Input: 4 channel dc 0-5v signal
1-wire: 1 channel
digital input: 1 channel (dry contact signal)
I2C bus: 1
Hi, how many slaves can be connected to one gateway?
if you can write your own arduino code , it's no limit. just according to your software code.
I would like to use it with home assistant and NOT have to develop any code. Would the Home Assistant be able to discover all the devices connected to it?
if you using our firmware, it's just a demo, only one "slave" board.
