  • 2 Vote(s) - 5 Average
KC868-H32B V5.08 firmware
#11
great post
Hi Admin,
Does the firmware upgrade reset the config to factory default or the configuration is preserved during FW upgrade?
Thanks.
after download firmware, the config will be clear. Need to set again.
I'm completely new to this.
I recently purchased an H32B Pro relay controller and need to integrate it with a Raspberry Pi 5 and Home Assistant. My goal is to use the relays to control the lighting system of my small vertical farm on a timer.
I bought the H32B a month ago, but unfortunately, it came with an outdated firmware version: H32B_Pro_V1.19. I was expecting it to be updated before shipping, so this is quite disappointing. From what I’ve read here, it looks like I need firmware version 4 for proper integration.
The issue is that I only have Apple Macs in my office, and my only connection options are LAN via the modem or Wi-Fi.
I have no idea how to update the firmware, which version to download, or how to install it. Any guidance would be greatly appreciated!
Thanks in advance.
H32B_Pro_V1.19 already is newest firmware.
you are looking at H32B, NOT H32B Pro.
so your firmware can work with interlock mode is OK, you want "interlock" option with your motor.
