Threads: 1
04-24-2025, 12:09 AM
I’m injecting 5v on the pins AI1-8 and they are supposed to read 0-5v but in Home Assistant they read 3.150v
I used the pin 5v from the board to test it too, only reads 3.150v
Threads: 1,604
what voltage value showed in KCS monitor webpage?
Threads: 1,604
do you want download KCS firmware or firmware by ESPHome yaml?
Threads: 1,604
which channel you have connected with analog signal, you can take a photo how you wire, we can test as your photo.
Threads: 1
Is the ADC sensor good enough for millivolt readings?
Are the sensors reading 0-5v or something else and then transforming it with calculations?
