MQTT Auto discovery problem
Hello everyone,
I am using board A16v3 with KCS v3.9.4 firmware.
I am trying to connect it with Home Assistant through ''MQTT (For Home Assistant)'' with auto discovery option set to ON, but unfortunately it cant connect to HA. I have watched kincony youtube videos and I am doing exactly the same, but with no success.
I have tried to connect with just the MQTT option and it connects just fine, but I would like to use the  ''MQTT (For Home Assistant)'' with auto discovery option. Have you came across such problem?
Any help will be appreciated.
take a photo of your setting screen.
[Image: FRNlnYF][Image: FRNlC21][Image: FRNlokg][Image: FRNlfEB]You can see with the regular MQTT option it connects to HA normally, but with the auto discovery option it stays disconnected.
sorry, i can't see any images.
because you have not input mqtt port: 1883, that is grey color, NOT enter.
Thank you for your quick support! I works perfectly now!
