07-01-2025, 10:46 PM
My KC868 server16 has a GSM module. How do I use the GSM module in server16 to do sms and calls
KC868 server16 and GSM module
07-01-2025, 11:33 PM
do you use by home asisstant or Node-red or other software solution?
07-02-2025, 03:31 AM
07-02-2025, 04:09 AM
you can use home assistant send command by UART serial port using SIM7600 AT command.
07-02-2025, 06:06 AM
07-02-2025, 08:14 PM
Can the GSM module in KC868 server16 fit into A32 Pro Smart Controller?
07-03-2025, 02:33 AM
Can the GSM module in KC868 server16 fit into A32 Pro Smart Controller? -- Yes, use by same GSM module.
here is AT command document for SIM7600E
SIM7500_SIM7600 Series_AT Command Manual_V2.00.pdf (Size: 2.72 MB / Downloads: 635)
07-03-2025, 05:28 AM
All the USB in server16 is disabled after HA installation. How do I enable them
07-03-2025, 07:57 AM
08-30-2025, 05:29 AM
(07-02-2025, 06:06 AM)fdcemb5 Wrote:(07-02-2025, 04:09 AM)admin Wrote: You can use Home Assistant to send commands via the UART serial port using the SIM7600 AT command. I cannot find any example on how to use Home Assistant to send commands via the UART serial port using the SIM7600 AT command. Kindly help with a concrete example |
| 1 Guest(s) |
