02-22-2025, 01:53 AM
friendly_name: b16
platformio_options:
board_build.extra_flags:
# WIFI_CONTROL_SELF_MODE = 0
# WIFI_CONTROL_SELF_MODE = 1
board: esp32-s3-devkitc-1
type: arduino
external_components:
- source:
type: git
ref: v1.1.0
# logger:
encryption:
type: W5500
clk_pin: GPIO1
mosi_pin: GPIO2
miso_pin: GPIO41
cs_pin: GPIO42
interrupt_pin: GPIO43
reset_pin: GPIO44
- id: bus_a
sda: 8
scl: 18
frequency: 400kHz
- id: 'pcf8574_hub_out_1' # for output channel 1-16
i2c_id: bus_a
address: 0x22
pcf8575: true
- id: 'pcf8574_hub_in_1' # for input channel 1-16
i2c_id: bus_a
address: 0x24
pcf8575: true
uart:
- id: uart_1 #RS485
baud_rate: 9600
debug:
direction: BOTH
dummy_receiver: true
after:
timeout: 10ms
tx_pin: 39
rx_pin: 38
- id: tuya_mcu_uart
tx_pin: GPIO16
rx_pin: GPIO17
baud_rate: 9600
tuya_wifi_mcu:
# tuya mcu product id
product_id: byxtsco8rwt4x8km
uart_id: tuya_mcu_uart
wifi_reset_pin: 28
wifi_led_pin: 16
- platform: uart
uart_id: uart_1
pcf8574: pcf8574_hub_out_1
mode: OUTPUT
- platform: tuya_wifi_mcu
dp_id: 1
# hide from homeassistant ui
internal: true
bind_switch_id: "b16_output01"
mode: OUTPUT
dp_id: 2
internal: true
bind_switch_id: "b16_output02"
mode: OUTPUT
dp_id: 3
internal: true
bind_switch_id: "b16_output03"
mode: OUTPUT
dp_id: 4
internal: true
bind_switch_id: "b16_output04"
number: 4
mode: OUTPUT
dp_id: 5
internal: true
bind_switch_id: "b16_output05"
number: 5
mode: OUTPUT
dp_id: 6
internal: true
bind_switch_id: "b16_output06"
number: 6
mode: OUTPUT
dp_id: 101
internal: true
bind_switch_id: "b16_output07"
number: 7
mode: OUTPUT
dp_id: 102
internal: true
bind_switch_id: "b16_output08"
number: 8
mode: OUTPUT
dp_id: 103
internal: true
bind_switch_id: "b16_output09"
number: 9
mode: OUTPUT
dp_id: 104
internal: true
bind_switch_id: "b16_output10"
number: 10
mode: OUTPUT
dp_id: 105
internal: true
bind_switch_id: "b16_output11"
number: 11
mode: OUTPUT
dp_id: 106
internal: true
bind_switch_id: "b16_output12"
number: 12
mode: OUTPUT
dp_id: 107
internal: true
bind_switch_id: "b16_output13"
number: 13
mode: OUTPUT
dp_id: 108
internal: true
bind_switch_id: "b16_output14"
number: 14
mode: OUTPUT
dp_id: 109
internal: true
bind_switch_id: "b16_output15"
number: 15
mode: OUTPUT
dp_id: 110
internal: true
bind_switch_id: "b16_output16"
pcf8574: pcf8574_hub_in_1
dp_id: 111
bind_binary_sensor_id: b16_input01
internal: true
dp_id: 112
bind_binary_sensor_id: b16_input02
internal: true
dp_id: 113
bind_binary_sensor_id: b16_input03
internal: true
dp_id: 114
bind_binary_sensor_id: b16_input04
internal: true
number: 4
dp_id: 115
bind_binary_sensor_id: b16_input05
internal: true
number: 5
dp_id: 116
bind_binary_sensor_id: b16_input06
internal: true
number: 6
dp_id: 117
bind_binary_sensor_id: b16_input07
internal: true
number: 7
dp_id: 118
bind_binary_sensor_id: b16_input08
internal: true
number: 8
dp_id: 119
bind_binary_sensor_id: b16_input09
internal: true
number: 9
dp_id: 120
bind_binary_sensor_id: b16_input10
internal: true
number: 10
dp_id: 121
bind_binary_sensor_id: b16_input11
internal: true
number: 11
dp_id: 122
bind_binary_sensor_id: b16_input12
internal: true
number: 12
dp_id: 123
bind_binary_sensor_id: b16_input13
internal: true
number: 13
dp_id: 124
bind_binary_sensor_id: b16_input14
internal: true
number: 14
dp_id: 125
bind_binary_sensor_id: b16_input15
internal: true
number: 15
dp_id: 126
bind_binary_sensor_id: b16_input16
internal: true
##pull-up resistance on PCB
number: 48
number: 47
number: 40
number: 7
## without resistance on PCB
number: 13
inverted: false
number: 14
inverted: false
number: 21
inverted: false
inverted: false
ads1115:
- address: 0x48
- platform: ads1115
multiplexer: 'A0_GND'
gain: 6.144
resolution: 16_BITS
update_interval: 5s
- platform: ads1115
multiplexer: 'A1_GND'
gain: 6.144
update_interval: 5s
- platform: ads1115
multiplexer: 'A2_GND'
gain: 6.144
update_interval: 5s
- platform: ads1115
multiplexer: 'A3_GND'
gain: 6.144
update_interval: 5s
web_server:
port: 80
font:
- file: "gfonts://Roboto"
display:
- platform: ssd1306_i2c
i2c_id: bus_a
model: "SSD1306 128x64"
address: 0x3C
lambda: |-
it.printf(0, 0, id(roboto), "KinCony B16");
B16-HA.txt (Size: 13.84 KB / Downloads: 659)
et_serial(USBCDC*)'
