08-02-2025, 10:27 AM
I need dimentions for this board, making a front panel. What is the spacing between switches and LED's? Can you publish a PDF-drawing with dimentions for this board?
KC868_E16S dimentions
08-02-2025, 11:06 AM
this is KC868-E16S PCB autocad file "KC868_E16S_V104.DWG", whether help for you?
KC868_E16S_V104.zip (Size: 271.56 KB / Downloads: 538)
08-02-2025, 12:49 PM
I also need the upper switch/led pcb dimentions.
08-03-2025, 12:06 AM
KC868-E16S only one pcb, maybe you can take a photo of your board.
It is E16P units i have, not E16S.
08-03-2025, 10:57 PM
this is E16P, not E16S.
E16P bottom pcb CAD file:
KINCONY-E16P-V203.zip (Size: 309.44 KB / Downloads: 515)
E16P top pcb CAD file:
KINCONY-E16PEXT-V103.zip (Size: 85.14 KB / Downloads: 522)
03-20-2026, 04:06 AM
Could you clarify what the specific dimensions for the spacing between the switches and LEDs are on the E16P board? Also, how can I access the CAD files for both the top and bottom PCBs?
03-20-2026, 07:23 AM
Can you label the size data you want on the photo?
04-02-2026, 01:55 AM
I also need exact measurements for spacing between switches and LEDs, and a detailed PDF drawing for accurate front panel design.
04-02-2026, 02:02 AM
i suggest you chose F16, E16P will stop produce, it have replaced by new version F16. the F16 have shell.
| 1 Guest(s) |
