KC868-AI ESPHome demo config for home assistant
  platform: ESP32
  sda: 4
  scl: 5
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  # Optional manual IP
  manual_ip:
    static_ip: 192.168.1.198
    gateway: 192.168.1.1
    subnet: 255.255.255.0
    address: 0x24
    address: 0x25
  - id: 'pcf8574_hub_in_3'  # for input channel 17-24
    address: 0x21
  - id: 'pcf8574_hub_in_4'  # for input channel 25-32
    address: 0x22
  - id: 'pcf8574_hub_in_5'  # for input channel 33-40
    address: 0x26
  - id: 'pcf8574_hub_in_6'  # for input channel 41-48
    address: 0x23
# Individual outputs
      pcf8574: pcf8574_hub_in_1
      number: 4
      number: 5
      number: 6
      number: 7
      pcf8574: pcf8574_hub_in_2
      number: 4
      number: 5
      number: 6
      number: 7
      pcf8574: pcf8574_hub_in_3
      number: 4
      number: 5
      number: 6
      number: 7
      pcf8574: pcf8574_hub_in_4
      number: 4
      number: 5
      number: 6
      number: 7
      pcf8574: pcf8574_hub_in_5
      number: 4
      number: 5
      number: 6
      number: 7
      pcf8574: pcf8574_hub_in_6
      number: 4
      number: 5
      number: 6
      number: 7
.txt   KC868-AI_ESPhome.txt (Size: 7.9 KB / Downloads: 1,033)
I just received a number of boards among which are the AI/H32B/H16B/COLB/...
As I'm interested to integrate these into home assistant using esphome (over ethernet cable), I installed esphome with your modified config to the AI board.
This is the config I've used:
# esphome:
#   name: kincony-ai-00
#   friendly_name: Kincony-AI-00
# esp32:
#   board: esp32dev
#   framework:
#     type: arduino
  platform: ESP32
  encryption:
    key: "***"
  sda: 4
  scl: 5
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  phy_addr: 0
  # # Optional manual IP
  # manual_ip:
  #   static_ip: 192.168.2.210
  #   gateway: 192.168.2.2
  #   subnet: 255.255.255.0
    address: 0x24
    address: 0x25
    address: 0x21
........... exact same code as your template (removed to shorten this reply)
After installing the code I get this in the logs:
ets Jul 29 2019 12:21:46
rst:0x1 (POWERON_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:2
load:0x3fff0030,len:1184
load:0x40078000,len:13132
load:0x40080400,len:3036
entry 0x400805e4
[I][logger:259]: Log initialized
[I][app:029]: Running through setup()...
[I][i2c.arduino:183]: Performing I2C bus recovery
[C][pcf8574:010]: Setting up PCF8574...
[D][binary_sensor:034]: 'ai-input1': Sending initial state OFF
[D][binary_sensor:034]: 'ai-input2': Sending initial state OFF
[D][binary_sensor:034]: 'ai-input3': Sending initial state OFF
.... (removed lines to shorten reply)
[D][binary_sensor:034]: 'ai-input45': Sending initial state OFF
[D][binary_sensor:034]: 'ai-input46': Sending initial state OFF
[D][binary_sensor:034]: 'ai-input47': Sending initial state OFF
[D][binary_sensor:034]: 'ai-input48': Sending initial state OFF
[C][ethernet:028]: Setting up Ethernet...
[I][ethernet:113]: Starting ethernet connection
[W][ethernet:130]: Connecting via ethernet failed! Re-connecting...
Seems there is something with the ethernet connection.
I'm sure the ethernet cable is working properly as I've connected earlier to my other boards and was able to access their html ui management portals.
Furthermore, the ethernet port on the AI is blinking on/off repeatedly, so not blinking (indicating that data is being sent) just 1sec on 1sec off...
How to update/adjust to properly install this board.
Thank you
Pieter
Additionally, I just tried to replace the ethernet connection setup, with my default wifi config.
This works and in that way I'm able to add my AI board via esphome to home assistant (see attachment).
So this would mean there is something wrong with the ethernet config?
Please assist me in resolving this issue.
Thanks
Pieter
after you download your firmware, just re power on of your board.
KC868-AI for ESPHome 2025.11.0 version. yaml file:
.txt   KC868-AI_ESPhome.txt (Size: 7.83 KB / Downloads: 329)
  friendly_name: kc868-ai
    type: esp-idf
  sda: 4
  scl: 5
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  phy_addr: 0
    address: 0x24
    address: 0x25
    address: 0x21
    address: 0x22
    address: 0x26
    address: 0x23
      number: 4
      number: 5
      number: 6
      number: 7
      number: 4
      number: 5
      number: 6
      number: 7
      number: 4
      number: 5
      number: 6
      number: 7
      number: 4
      number: 5
      number: 6
      number: 7
      number: 4
      number: 5
      number: 6
      number: 7
      number: 4
      number: 5
      number: 6
      number: 7
