KC868-E16T added Tuya module and input toggle output yaml file for ESPHome
  platformio_options:
    board_build.extra_flags:
      # WIFI_CONTROL_SELF_MODE = 0
      # WIFI_CONTROL_SELF_MODE = 1
      - "-DWIFI_CONTROL_SELF_MODE=0"
    type: arduino
external_components:
  - source:
      type: git
      ref: v1.1.0
uart:
  tx_pin: 33
  rx_pin: 14
  baud_rate: 9600
tuya_wifi_mcu:
  # tuya mcu product id
  product_id: tfj1dtlneyxp5uya
  uart_id: tuya_mcu_uart
  wifi_reset_pin: 5
  wifi_led_pin: 12
  sda: 16
  scl: 15
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
    address: 0x21
    address: 0x25
    address: 0x22
    address: 0x24
# Individual outputs
      pcf8574: pcf8574_hub_out_1
      mode: OUTPUT
  - platform: tuya_wifi_mcu
    dp_id: 1
    # hide from homeassistant ui
    internal: true
    bind_switch_id: "e16t_output1"
      mode: OUTPUT
    dp_id: 2
    internal: true
    bind_switch_id: "e16t_output2"
      mode: OUTPUT
    dp_id: 3
    internal: true
    bind_switch_id: "e16t_output3"
      mode: OUTPUT
    dp_id: 4
    internal: true
    bind_switch_id: "e16t_output4"
      number: 4
      mode: OUTPUT
    dp_id: 5
    internal: true
    bind_switch_id: "e16t_output5"
      number: 5
      mode: OUTPUT
    dp_id: 6
    internal: true
    bind_switch_id: "e16t_output6"
      number: 6
      mode: OUTPUT
    dp_id: 101
    internal: true
    bind_switch_id: "e16t_output7"
      number: 7
      mode: OUTPUT
    dp_id: 102
    internal: true
    bind_switch_id: "e16t_output8"
      pcf8574: pcf8574_hub_out_2
      mode: OUTPUT
    dp_id: 103
    internal: true
    bind_switch_id: "e16t_output9"
      mode: OUTPUT
    dp_id: 104
    internal: true
    bind_switch_id: "e16t_output10"
      mode: OUTPUT
    dp_id: 105
    internal: true
    bind_switch_id: "e16t_output11"
      mode: OUTPUT
    dp_id: 106
    internal: true
    bind_switch_id: "e16t_output12"
      number: 4
      mode: OUTPUT
    dp_id: 107
    internal: true
    bind_switch_id: "e16t_output13"
      number: 5
      mode: OUTPUT
    dp_id: 108
    internal: true
    bind_switch_id: "e16t_output14"
      number: 6
      mode: OUTPUT
    dp_id: 109
    internal: true
    bind_switch_id: "e16t_output15"
      number: 7
      mode: OUTPUT
    dp_id: 110
    internal: true
    bind_switch_id: "e16t_output16"
      pcf8574: pcf8574_hub_in_1
    on_press:
      then:
        - switch.toggle: e16t_output1
    name: e16t DI01 Tuya
    dp_id: 111
    bind_binary_sensor_id: e16t_input1
    internal: true
    on_press:
      then:
        - switch.toggle: e16t_output2
    name: e16t DI02 Tuya
    dp_id: 112
    bind_binary_sensor_id: e16t_input2
    internal: true
    on_press:
      then:
        - switch.toggle: e16t_output3
    name: e16t DI03 Tuya
    dp_id: 113
    bind_binary_sensor_id: e16t_input3
    internal: true
    on_press:
      then:
        - switch.toggle: e16t_output4
    name: e16t DI04 Tuya
    dp_id: 114
    bind_binary_sensor_id: e16t_input4
    internal: true
      number: 4
    on_press:
      then:
        - switch.toggle: e16t_output5
    name: e16t DI05 Tuya
    dp_id: 115
    bind_binary_sensor_id: e16t_input5
    internal: true
      number: 5
    on_press:
      then:
        - switch.toggle: e16t_output6
    name: e16t DI06 Tuya
    dp_id: 116
    bind_binary_sensor_id: e16t_input6
    internal: true
      number: 6
    on_press:
      then:
        - switch.toggle: e16t_output7
    name: e16t DI07 Tuya
    dp_id: 117
    bind_binary_sensor_id: e16t_input7
    internal: true
      number: 7
    on_press:
      then:
        - switch.toggle: e16t_output8
    name: e16t DI08 Tuya
    dp_id: 118
    bind_binary_sensor_id: e16t_input8
    internal: true
      pcf8574: pcf8574_hub_in_2
    on_press:
      then:
        - switch.toggle: e16t_output9
    name: e16t DI09 Tuya
    dp_id: 119
    bind_binary_sensor_id: e16t_input9
    internal: true
    on_press:
      then:
        - switch.toggle: e16t_output10
    name: e16t DI10 Tuya
    dp_id: 120
    bind_binary_sensor_id: e16t_input10
    internal: true
    on_press:
      then:
        - switch.toggle: e16t_output11
    name: e16t DI11 Tuya
    dp_id: 121
    bind_binary_sensor_id: e16t_input11
    internal: true
    on_press:
      then:
        - switch.toggle: e16t_output12
    name: e16t DI12 Tuya
    dp_id: 122
    bind_binary_sensor_id: e16t_input12
    internal: true
      number: 4
    on_press:
      then:
        - switch.toggle: e16t_output13
    name: e16t DI13 Tuya
    dp_id: 123
    bind_binary_sensor_id: e16t_input13
    internal: true
      number: 5
    on_press:
      then:
        - switch.toggle: e16t_output14
    name: e16t DI14 Tuya
    dp_id: 124
    bind_binary_sensor_id: e16t_input14
    internal: true
      number: 6
    on_press:
      then:
        - switch.toggle: e16t_output15
    name: e16t DI15 Tuya
    dp_id: 125
    bind_binary_sensor_id: e16t_input15
    internal: true
      number: 7
    on_press:
      then:
        - switch.toggle: e16t_output16
    name: e16t DI16 Tuya
    dp_id: 126
    bind_binary_sensor_id: e16t_input16
    internal: true
firmware BIN file download:
.zip   e16t.factory_tuya.zip (Size: 372.83 KB / Downloads: 826)
Hello, I would like to know the cost value , and I would like a video explaining how to change the input status to make it temporary using a contactor. I need this information. Thank you.
do you want digital input toggle relay output?
address should be 0x0
(12-01-2025, 02:33 AM)admin Wrote: address should be 0x0
After many attempts, I only got an error: I can't install the yml file.
I need the first 5 buttons to only be lit when a switch is activated. If you have a ready-made bin file that works on Tuya, it would help me.
my order about AliExpress  number 3061729049605348
thanks fernando
just modify esphome yaml file with 5 digital input ports with TOGGLE relay.
