10-16-2025, 08:24 AM
Connect um330 and kc828 a16
10-16-2025, 10:43 AM
KC868-COLB is 16 channel 0-5v analog input ports, you can convert to 4-20mA, so that can integrate to home assistant by MQTT.
11-18-2025, 08:18 AM
(10-16-2025, 10:43 AM)admin Wrote: KC868-COLB is 16 channel 0-5v analog input ports, you can convert to 4-20mA, so that can integrate to home assistant by MQTT. Is direct shipping to South Korea available? Online Store: https://shop.kincony.com
11-18-2025, 10:13 PM
sure, it's ok.
01-07-2026, 07:17 AM
COLB integrate to home assistant by mqtt, here is guide: https://www.kincony.com/mqtt-input-modul...stant.html
COLB analog input port for 0-5v
01-08-2026, 01:15 AM
(01-07-2026, 07:17 AM)admin Wrote: COLB integrate to home assistant by mqtt, here is guide: https://www.kincony.com/mqtt-input-modul...stant.html Previously, I was told that it’s possible to convert a 4–20 mA signal for use with the COLB. Could you please explain how to do that? Also, is MQTT integration with Home Assistant possible over Wi-Fi, or is it only supported via Ethernet? (10-16-2025, 10:43 AM)admin Wrote: KC868-COLB is 16 channel 0-5v analog input ports, you can convert to 4-20mA, so that can integrate to home assistant by MQTT.
01-08-2026, 01:44 AM
yes, COLB direct use by 0-5v, if you want use by 4-20mA, you can add extend convert module, there are many 0-5v to 4-20mA small module on market, you can search it.
MQTT only use by ethernet. wifi is not stable.
01-08-2026, 06:21 PM
(01-08-2026, 01:44 AM)admin Wrote: yes, COLB direct use by 0-5v, if you want use by 4-20mA, you can add extend convert module, there are many 0-5v to 4-20mA small module on market, you can search it. Can I still read the current correctly if I connect a 250-ohm resistor across the + and − terminals?
01-09-2026, 12:52 AM
if you read by current, can't read by voltage.
| 1 Guest(s) |
