N60 Sensor channel label
#11
(04-19-2026, 04:05 AM)admin Wrote: 1: about "power factor" we will check and later feedback to you.
2: here is new KCS firmware, support rename for every channel and update to home assistant by mqtt auto discovery.
just double click the channel name, you can rename by yourself.
firmware BIN file download:
Thank you!!
1: the "power factor" according to channel1. BL0910 chip only have one channel power factor, can't monitor 10 channels.
(04-20-2026, 12:09 AM)admin Wrote: 1: the "power factor" according to channel1. BL0910 chip only have one channel power factor, can't monitor 10 channels.
Ok, thank you for checking.
Can you tell me if there is a procedure to properly calibrate  the measurements on each of the channels?
use PC software for that:
[Image: attachment.php?aid=9284]
pc software download link: https://www.kincony.com/forum/showthread.php?tid=8406
(04-20-2026, 02:26 AM)admin Wrote: use PC software for that:
Great, Thank you!
here is N60 new firmware, support DST now, you can test it, whether is you wanted.
.zip   KCS_N60_V3.25.0_beta_20260515-142317.zip (Size: 1.04 MB / Downloads: 288)
Thank you for marking changes to allow for the custom Channel name feature.  I do have one more ask however.  Would it be possible to allow longer names (more characters) right now I believe allowed number of characters is 16.  I believe 32 characters should be sufficient.
Thank you in advance.
we will check, maybe in future, next update.
(08-14-2026, 01:50 AM)admin Wrote: we will check, maybe in future, next update.
Thank you!
you can update this new firmware for testing.
New KCS V3.27.4_beta_20261012-010554 Test Firmware:
1. Added a manual current direction reversal setting for CT sensors.
2. Extended the maximum CT sensor channel name length to 32 characters.
3. Moved “Clear All Energy Data” to the Energy → Settings page, with separate options for “Clear All Energy Data” and “Reset Calibration Factors.”
4. Added the statistics attribute to MQTT messages reported to Home Assistant.
5. Fixed missing CRC validation in certain cases that could result in incorrect data.
6. Fixed an issue on N-series energy meters where MQTT reported incorrect zero energy readings after the initial power-up.
.zip   KCS_N60_V3.27.4_beta_20261012-010838.zip (Size: 1.11 MB / Downloads: 66)
.zip   KCS_N30_V3.27.4_beta_20261012-010554.zip (Size: 1.09 MB / Downloads: 56)
