KC868-COLB V2.4 firmware support Tuya app
Tongue
improvement:
1. support use Tuya app for remote monitor sensor state.
2. support TCP Server, TCP Client, MQTT, Tuya different protocol at the same time by ethernet.
such as you can use Home assistant (by mqtt) in local LAN network and Tuya app for remote monitor by internet.
if you buy KC868-COLB before 2023-3-1 , you need to update your BOOTLOADER HEX file for your CPU.
Because the new firmware 2.4 is big and powerful. So you need to do two steps for update fireware.
1. update your CPU BOOTLOADER by Jlink tool.
2. update your firmware BIN file by USB-RS232 cable.
here are details:
for example, your KC868-COLB CPU chip is AT32F403AVGT7.
so download AT-link tool for flash BOOTLOADER.
.zip   Artery_ICP_Programmer_V3.0.07.zip (Size: 14.28 MB / Downloads: 989)
BOOTLOADER HEX file download
.zip   Bootloader_AD_V2_0_2_20210913.zip (Size: 4.88 KB / Downloads: 1,006)
open your KC868-COLB metal box
installed jlink computer driver and ready to use it.
here is pin define , connect jlink to your KC868-COLB PCB's download interface
begin download BOOTLOADER HEX file , just do as follow images:
after download BOOTLOADER completed, begin use RS232 download tool to download BIN file.
RS232 download tool:
https://www.kincony.com/download/KC868-C...loader.zip
BIN file download:
.zip   AD_COLB_V2_4_230228.zip (Size: 112.17 KB / Downloads: 1,007)
begin download BIN file , just do as follow images:
now all are completed, have a good timeSmile
Note: if you want to use Tuya mobile phoen app with KC868-COLB, need contact with us to buy Tuya lincence for KC868-COLB.
I’m trying to update my CPU OF H32B by jlink, i downloaded icp programer and add the bootloader file. When i press connect then it gives a message that shows in the picture.
What can be the problem?
H32B bottom pcb side have a black CPU, take a photo, what's the model.
This is my cpu photo
it's old CPU, not enough memory for newest firmware. you not need update firmware.
I know its old, im trying to update by jlink, but it gives a message that shows in the picture above!!
Can you tell what is the problem? And what i should do?
only AT32F chip can update.
But if I use jlink to update Bootloader HEX file for my CPU, then update to newest firmware, it should work?
I saw a video explaining this :
https://youtu.be/Uvl0FNVOORs?si=LgasM7jjv4We9SOo
AT32F chip download firmware by AT-link.
So STM32F can’t be update at all even by jlink?g
