07-01-2024, 12:00 PM
great post
KC868-H32B V5.08 firmware
great post
08-27-2024, 07:19 PM
Hi Admin,
Does the firmware upgrade reset the config to factory default or the configuration is preserved during FW upgrade? Thanks.
08-27-2024, 09:59 PM
after download firmware, the config will be clear. Need to set again.
02-10-2025, 12:56 PM
I'm completely new to this.
I recently purchased an H32B Pro relay controller and need to integrate it with a Raspberry Pi 5 and Home Assistant. My goal is to use the relays to control the lighting system of my small vertical farm on a timer. I bought the H32B a month ago, but unfortunately, it came with an outdated firmware version: H32B_Pro_V1.19. I was expecting it to be updated before shipping, so this is quite disappointing. From what I’ve read here, it looks like I need firmware version 4 for proper integration. The issue is that I only have Apple Macs in my office, and my only connection options are LAN via the modem or Wi-Fi. I have no idea how to update the firmware, which version to download, or how to install it. Any guidance would be greatly appreciated! Thanks in advance.
02-10-2025, 12:59 PM
H32B_Pro_V1.19 already is newest firmware.
you are looking at H32B, NOT H32B Pro. so your firmware can work with interlock mode is OK, you want "interlock" option with your motor.
07-22-2026, 03:25 PM
Im using this controller for about 3 years in home, i have one bug that is making life hard.
The controller connected to kc868 AK and many switches, the issue after some days it start have delay with response to the switch, and after more days it stop responding at all. I need to turn off and on. It solve the issue. Im using right now v5.08. because tuya app. I do prefer to work with old FW that dont have this bug, but at least have the interlock option, because im using the controller for the windows up/down. Do you have an solution for me? I will be appropriate for it
07-22-2026, 09:53 PM
v5.08 also have "interlock" option.
Yesterday, 05:22 AM
Yesterday, 06:53 AM
v5.08 is newest firmware for H32B controller.
Yesterday, 07:32 PM
| 1 Guest(s) |
