RC snubber wiring
Can you please confirm the following wiring of the RC snubber with a KC868-H32B for a furnace valve is OK ?
[Image: kincony-rc-snubber.jpg]
what's your valve work voltage?
(12-30-2021, 11:33 PM)admin Wrote: what's your valve work voltage?
230V AC 50Hz
RC snubber connect with valve's coin two point. Parallel with blue and purple wires
(12-31-2021, 07:50 AM)admin Wrote: RC snubber connect with valve's coin two point. Parallel with blue and purple wires
Like this then ?
[Image: kincony-rc-snubber-3.jpg]
correct. But your photo i think not show wholely? right line not deleted?
(01-01-2022, 02:38 AM)admin Wrote: correct. But your photo i think not show wholely? right line not deleted?
sorry, I don't understand. What right line ?
your diagram is right.
(01-01-2022, 05:59 AM)admin Wrote: your diagram is right.
The RC snubbers did not solve my issue: after less than 3 days with the Kincony RC snubbers installed as indicated in the above diagram, I ran into the same problem: the KC868-H32 MQTT stack stops responding for all relays, turning the Kincony device into a useless brick.
[Image: kincony1.jpg][Image: kincony2.jpg]
Please advise.
can you take big photo and upload a full diagram how you wire? your photo to smal , not easy to check.
