K868-Uair proper GPIO assignation ?
Hi
I'm tyring to use a K868-Uair with ESPHome but I have some problems ! According at Kincony ducomentation it should GPIO32 and 33 to control RGB LEDs of bottom ring and vertical bar ! Unhappy these two GPIOs are doing exactly the same thing: control the ring only and only 3 LEDs of it Sad
Someone has the proper GPIO configuration of that board ?
Noticed also that the Dallas temperature sensor is a chinese copy I think as it's 4/5° offset of other temperature sensors I have in the room Sad
Code used so far in ESPHome for LEDs:
light:
  - platform: neopixelbus
    type: GRB
    variant: WS2812X
    pin: GPIO33
    num_leds: 4
    type: GRB
    variant: WS2812X
    pin: GPIO32
    num_leds: 4
Thanks for help
Vincèn
  platform: ESP32
ota:
  password: "978e66f878ed5041b830cfb427393c79"
wifi:
  ssid: "KinCony"  # your wifi router ssid
  password: "12345678"  # your wifi password
  ap:
    ssid: "Kc868-Uair Fallback Hotspot"
    password: "FbTxCLlbDvbO"
captive_portal:
# follow configure use for DS18B20 temperature sensor, SHT30 temperature and humidity sensor. WS2812B RGB LEDs.
  sda: 4
  scl: 16
dallas:
  - pin: GPIO27
    update_interval: 15s
# Individual sensors
  - platform: dallas
    address: 0xC000000004D81528  # your DS18B20 address
    name: "internal Temperature"
  - platform: sht3xd
    temperature:
      name: "extend Temperature"
    humidity:
      name: "extend Humidity"
    address: 0x44
light:
  - platform: fastled_clockless
    chipset: WS2812B
    pin: GPIO32    # Pin Define connected with LED strip
    num_leds: 4  #LEDs number
    rgb_order: GRB
    effects:
      - addressable_rainbow:        ##defined 7 effects styles
      - addressable_color_wipe:
      - addressable_scan:
      - addressable_twinkle:
      - addressable_random_twinkle:
      - addressable_fireworks:
      - addressable_flicker:
    chipset: WS2812B
    pin: GPIO33    # Pin Define connected with LED strip
    num_leds: 1  #LEDs number
    rgb_order: RGB
    effects:
      - addressable_scan:
.zip   Made_for_ESPHome_KC868-Uair.zip (Size: 935 bytes / Downloads: 737)
(03-09-2022, 09:34 AM)vincen Wrote: Hi
light:
    type: GRB
    variant: WS2812X
    pin: GPIO33
    num_leds: 4
    type: GRB
    variant: WS2812X
    pin: GPIO32
    num_leds: 4
Thanks for help
Vincèn
GPIO33 use for 1 LED
GPIO32 use for 4 LED
light:
    type: GRB
    variant: WS2812X
    pin: GPIO33
    num_leds: 4
    type: GRB
    variant: WS2812X
    pin: GPIO32
    num_leds: 4
Thanks for help
Vincèn
Thanks for code it works this way but it's using old RGB implementation mode of ESPHome Wink
In fact the device has a hardware issue as one of the ring LED is wired with bar so only 3 LEDs of ring work together, the other one works with bar which kills the visual effect of the ring !! Are you aware of that problem on the device ??
[Image: IMG_20220311_193517.jpg]
(03-11-2022, 07:03 PM)vincen Wrote: In fact the device has a hardware issue as one of the ring LED is wired with bar so only 3 LEDs of ring work together, the other one works with bar which kills the visual effect of the ring !! Are you aware of that problem on the device ??
no, 4 LEDs work together with ring LED. another one LED is indepentant. here is diagram, you can see details.
(03-11-2022, 11:03 PM)admin Wrote: no, 4 LEDs work together with ring LED. another one LED is indepentant. here is diagram, you can see details.
Thanks for the schematics but it doesn't correspond with reality ! Have a look at my picture you can clearly one of the LED is not following the other ones on ring but the ones of bar Sad
do you use my code directly? or changed something?
(03-12-2022, 01:44 PM)admin Wrote: do you use my code directly? or changed something?
I use your code nearly without modifications, here it is:
substitutions:
  friendly_name: kincony-netatmo
    type: arduino
web_server:
ota:
wifi:
  networks:
  - ssid: !secret wifi
    password: !secret wifi_passwd
  - ssid: !secret wifi_puppy
    password: !secret wifi_puppy_passwd
  ap:
    ssid: $friendly_name
captive_portal:
  reboot_timeout: 120min
#i2c:
#  sda: 4
#  scl: 16
#  scan: true
#  id: bus_a
dallas:
  - pin: GPIO27
  - platform: dallas
    address: 0x0800000004680128
light:
    chipset: WS2812B
    rgb_order: GRB
    effects:
      - addressable_scan:
    chipset: WS2812B
    rgb_order: RGB
    effects:
      - addressable_scan:
i think you need to check software, hardware is no problem, here is some our demo images.
