KC868-Server V1.48 new firmware update
improvement:
add manufactory test commands for RS232
command-1 for set to test mode:
    set static IP:192.168.1.200 for ethernet
    set wifi work mode=TCP Server
    set ethernet work mode=TCP Server
    enable 4 chanenl analog input auto report
    set board RS485 address=1
    set board RS485 Baud rate=9600bps
command-2 for Restore factory settings:
    set wifi work mode=UDP
    set ethernet work mode=UDP
    disable 4 channel analog input auto report
.zip   KC868_SERVER_V148_220413.zip (Size: 54.15 KB / Downloads: 1,013)
download the ZIP file , unzip update the bin file for KC868-H32B relay controller by USB-RS232 cable or ethernet cable.
Hello.
i uploaded this firmware into the wifi TCP server page, but now it isn't work anymore... how can i reset it?
no, you have mistake update for the wifi module, you should update use by KinCony's update tool. give me your email, we send you the wifi module firmware.
(05-07-2022, 12:08 AM)admin Wrote: no, you have mistake update for the wifi module, you should update use by KinCony's update tool. give me your email, we send you the wifi module firmware.
This is my email:
deitoscristian@me.com
I upload the wifi firmware in the same mode as i uploaded the h32b 4.44 firmware?
this is how to update firmware: https://youtu.be/LLIJe9VTVq8
(05-07-2022, 08:42 AM)admin Wrote: this is how to update firmware: https://youtu.be/LLIJe9VTVq8
Ok, please can you send me the wifi firmware by email? Thank you a lot
Monday when begin work , send to you.
(05-07-2022, 12:22 PM)admin Wrote: Monday when begin work , send to you.
I have found this.. i tried to upload it by your firmware download tool but it doesn't work
http://www.hi-flying.com/download-center...0-firmware
can you find the AP "LPT230" , if you can find, just upload wifi module firmware as before.
Note:
wifi module firmware should upload by wifi module's tool (webpage)
controller's firmware upload by kincony's bootloader tool.
after you download the firmware package ZIP file, here have a file "HF-LPX30_Module_Upgrade and Debug_V1.4.pdf" , you can see here have details about download wifi module firmware.
