  • 1 Vote(s) - 5 Average
Lesson9 - integrate KC868-Server to home assistant by MQTT
#11
Failed to restart Home Assistant
The system cannot restart because the configuration is not valid: Invalid config for [mqtt]: [name:] is an invalid option for [mqtt]. Check: mqtt->mqtt->switch->2->name:. (See /config/configuration.yaml, line 17).
.txt   switch.txt (Size: 7.66 KB / Downloads: 694)
You can see here , now format for MQTT home assistant:
https://www.kincony.com/kc868-h32b-integ...-mqtt.html
note: maybe you have some "space" in string. just a format problem.
can you check attach where the error
thank you
.txt   mqtt.txt (Size: 8 KB / Downloads: 765)
when using home assistant 2022.12.x version, mqtt syntax is updated.
delete these lines in your yaml file:
broker: 192.168.100.172
port: 1883
username: atawiali
password: P@ssw0rd
still not working
The system cannot restart because the configuration is not valid: Invalid config for [mqtt]: [name:] is an invalid option for [mqtt]. Check: mqtt->mqtt->switch->2->name:. (See /config/configuration.yaml, line 22).
see attach
here is my config file for KC868-Server work with home assistant 2022.12.5
.txt   KC868-Server-home-assistant-MQTT_config_202212.txt (Size: 9.26 KB / Downloads: 818)
thank you  for your reply
the swatch not response
see attach
.txt   mqtt.txt (Size: 9.26 KB / Downloads: 752)
1. check your mosquitto MQTT broker whether work well.
2. check your KC868-Server's ethernet setting, whether filled the correct MQTT IP,Port,Username,Password
I propably have a problem to configure mqtt broker.
my yaml configuration file, corrected version, adapted to update home assistant
.txt   konfiguracja mqtt serwer nowsza 19.01.2023.txt (Size: 9.26 KB / Downloads: 716)
my password and username on configuration mqtt broker
my configuration on ethernet kincony server setings before save
my configuration on ethernet kincony server setings after save new long password, mayby too long pasword is a problem ?
Allways status is unknowned, when i make entities switch i try to change status on / off in HA, it return to status on 2 sec later, in KC server nothing happens, the red leds on the pcb do not light up
