KC868-E16S/E16P demo configure for ESPhome
.txt   Made_for_ESPHome_KC868-E16S.txt (Size: 5.64 KB / Downloads: 1,123)
  platform: ESP32
  sda: 16
  scl: 15
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  # Optional manual IP
#  manual_ip:
#    static_ip: 192.168.1.199
#    gateway: 192.168.1.1
#    subnet: 255.255.255.0
    address: 0x21
    address: 0x25
    address: 0x22
    address: 0x24
# Individual outputs
      pcf8574: pcf8574_hub_out_1
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      pcf8574: pcf8574_hub_out_2
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      pcf8574: pcf8574_hub_in_1
      number: 4
      number: 5
      number: 6
      number: 7
      pcf8574: pcf8574_hub_in_2
      number: 4
      number: 5
      number: 6
      number: 7
hello,
I use this config which works with the buttons too and are in the right order
platform: ESP32
sda: 16
scl: 15
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
phy_addr: 0
# manual_ip:
address: 0x21
address: 0x25
address: 0x22
address: 0x24
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
mode: OUTPUT
number: 4
mode: OUTPUT
number: 5
mode: OUTPUT
number: 6
mode: OUTPUT
number: 7
mode: OUTPUT
#-----------INPUTS------------
on_press:
then:
- switch.toggle: output16
on_press:
then:
- switch.toggle: output15
on_press:
then:
- switch.toggle: output14
on_press:
then:
- switch.toggle: output13
on_press:
then:
- switch.toggle: output12
number: 4
on_press:
then:
- switch.toggle: output11
number: 5
on_press:
then:
- switch.toggle: output10
number: 6
on_press:
then:
- switch.toggle: output9
number: 7
on_press:
then:
- switch.toggle: output8
on_press:
then:
- switch.toggle: output7
on_press:
then:
- switch.toggle: output6
on_press:
then:
- switch.toggle: output5
on_press:
then:
- switch.toggle: output4
number: 4
on_press:
then:
- switch.toggle: output3
number: 5
on_press:
then:
- switch.toggle: output2
number: 6
on_press:
then:
number: 7
thanks share your config code.
Hello, good evening. What changes should I make in the code so that they appear as lights instead of switches? (I want to avoid doing the configuration in homeassistant through helpers).
edit Dashboard - entity , change ICO.
ESP32 IoT Board Issue with ESPHome Firmware Installation
Overview
I am experiencing issues with my new kc868-e16s board after installing custom esphome firmware. The board was expected to connect to a LAN via DHCP and control several relays, but it is currently not functioning as expected.
Environment
  • Board: kc868-e16s
  • Firmware: ESPHome
  • Operating System: Fedora (Linux)
  • Connection: USB to laptop
Issue Description
After successfully uploading the firmware:
  1. The Ethernet port does not establish a link and fails to obtain a DHCP lease.
  2. The physical buttons do not trigger the corresponding relays.
Prior Status
The board previously had the default firmware and was able to obtain a DHCP lease. However, the relays did not function through the web UI.
Steps Taken
  1. Created and validated ESPHome YAML configuration.
  2. Uploaded the firmware to the board.
  3. Observed no Ethernet link and non-functioning relays.
Supporting Information
  • YAML Configuration: Provided below.
  • dmesg Output: Shows successful USB connection and removal post-firmware upload.
  • ESPHome Validation: Confirms successful configuration validation.
  • ESPHome Upload: Indicates successful firmware upload.
  • Board Power Supply: 24v DC.
ESPHome YAML Configuration File
  platform: ESP32
  sda: 16
  scl: 15
    address: 0x21
    address: 0x25
    address: 0x22
    address: 0x24
# Ethernet configuration with DHCP
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  phy_addr: 0
    name: "Sol-Ark Grid Input Mercury Contactors"
      mode: OUTPUT
    name: "Electric Water Heater 1 - Top Element"
      mode: OUTPUT
    name: "Electric Water Heater 2 - Top Element"
      mode: OUTPUT
    name: "Electric Water Heater 1 - Bottom Element"
      mode: OUTPUT
    name: "Electric Water Heater 2 - Bottom Element"
      number: 4
      mode: OUTPUT
    name: "Hot Water Recirculation Pump"
      number: 5
      mode: OUTPUT
    name: "Geothermal Desuperheater Pump 3 Way Electronic Valve"
      number: 6
      mode: OUTPUT
    name: "Geothermal Desuperheater ByPass Electronic Valve"
      number: 7
      mode: OUTPUT
    name: "Electric Water Heater 1 - Output Cut Off Electronic Valve"
      mode: OUTPUT
    name: "Electric Water Heater 1 - Input Cut Off Electronic Valve"
      mode: OUTPUT
    name: "Electric Water Heater 1 - Recirculation Cut Off Electronic Valve"
      mode: OUTPUT
    name: "Sol-Ark Grid Input Mercury Contactors - Switch"
    on_press:
      then:
        - switch.toggle: sol_ark_grid_input_mercury_contactor
    name: "Electric Water Heater 1 - Top Element Switch"
    on_press:
      then:
        - switch.toggle: electric_water_heater_1_top_element
    name: "Electric Water Heater 2 - Top Element Switch"
    on_press:
      then:
        - switch.toggle: electric_water_heater_2_top_element
    name: "Electric Water Heater 1 - Bottom Element Switch"
    on_press:
      then:
        - switch.toggle: electric_water_heater_1_bottom_element
    name: "Electric Water Heater 2 - Bottom Element Switch"
      number: 4
    on_press:
      then:
        - switch.toggle: electric_water_heater_2_bottom_element
    name: "Hot Water Recirculation Pump - Switch"
      number: 5
    on_press:
      then:
        - switch.toggle: hot_water_recirculation_pump
    name: "Geothermal Desuperheater Pump 3 Way Electronic Valve - Switch"
      number: 6
    on_press:
      then:
        - switch.toggle: geothermal_desuperheater_pump_3_way_electronic_valve
    name: "Electric Water Heater 1 - Output Cut Off Electronic Valve - Switch"
      number: 7
    on_press:
      then:
        - switch.toggle: electric_water_heater_1_output_cut_off_electronic_valve
    name: "Electric Water Heater 1 - Input Cut Off Electronic Valve - Switch"
    on_press:
      then:
        - switch.toggle: electric_water_heater_1_input_cut_off_electronic_valve
    name: "Electric Water Heater 1 - Recirculation Cut Off Electronic Valve - Switch"
    on_press:
      then:
        - switch.toggle: electric_water_heater_1_recirculation_cut_off_electronic_valve
  level: debug
  password: <password>  # Add your password here for API access
dmesg Output Showing Successful USB Connection and Device Port
[15024.377787] usb 1-1: new full-speed USB device number 45 using xhci_hcd
[15024.508783] usb 1-1: ch341-uart converter now attached to ttyUSB0
[15347.157356] input: MX Keys Keyboard as /devices/virtual/misc/uhid/0005:046D:B35B.0021/input/input77
dmesg Output Showing Successful USB Removal After Firmware Upload
[15360.959985] usb 1-1: USB disconnect, device number 45
[15360.960088] ch341-uart ttyUSB0: ch341-uart converter now disconnected from ttyUSB0
[15360.960119] ch341 1-1:1.0: device disconnected
ESPHome YAML Validation Success
Truncated to fit post constraints
INFO Configuration is valid!
Successful Upload of Firmware to Board
(.venv) ➜  kc868-e16s git:(main) ✗ esphome upload --device /dev/ttyUSB0 --file ./.esphome/build/kc868-e16s/.pioenvs/kc868-e16s/firmware.bin kc868-e16s.yaml
INFO ESPHome 2023.12.5
Wrote 591904 bytes (362780 compressed) at 0x00000000 in 8.6 seconds (effective 549.5 kbit/s)...
Hash of data verified.
Leaving...
Hard resetting via RTS pin...
INFO Successfully uploaded program.
[Image: media?url=https%3A%2F%2Fi.redd.it%2Fs4qu6ma3eacc1.jpeg]
Matthew Dresden
Global DevSecOps Leader at Launch by NTT Data, INC
IOT and Alternative Power Enthusiasts
can you download KCS firmware for a testing? just make sure hardware is OK.
here is online guide: https://www.kincony.com/esp32-kcsv2-firmware.html
another thing, after you download firmware, do you have re power on of your board?
(01-14-2024, 12:33 AM)admin Wrote: can you download KCS firmware for a testing? just make sure hardware is OK.
I am able to install the firmware `KCS_KC868_A16S_V2.2.2.bin` with your tool
I have to power cycle the board for the lan to start working and ping the board.
From the web UI, I did not see a way to test the relays, but I can confirm the ethernet port is working.
For now I have my source for the yaml public in github in a branch at:  Link to yaml file on github
Which is still in the same state as what I posted.
I created a README.md for the steps I have take to flash the board with the compile firmware at Steps I took to flash my custom firmware
I also attempted to flash my custom firmware with your windows tool; which had the same failed result as my developement environment.
Matthew Dresden
if you have downloaded KCS firmware, open the webpage, there is "monitor" webpage, you can click relay ico for ON/OFF.
if you also have problem, add whatsapp number: +86-15381188302 we can use ANYDESK remote control your computer, have a look.
(01-14-2024, 02:39 AM)admin Wrote: if you have downloaded KCS firmware, open the webpage, there is "monitor" webpage, you can click relay ico for ON/OFF.
Install whats app and then we can connect for a remote session
Matthew Dresden
