Kincony A16 - PIR motion sensor
#11
I have 3 wire sensor.. without NO and NC.
Can you tell me how to wire this sensor with digital input pin of A16.
It has
VCC
Gnd
 output
How to wire this with A16??
can you take a photo of your sensor pcb, you need to confirm your sensor power supply voltage.
usually Vcc is dc12v, connect 12v and GND to sensor, then sensor's "output" and GND connect to KC868-A16's digital input port and GND.
Hi
I have hcr501 pir sensor it works with 5 to 12 v dc..
I tried hard but output is stuck.
My wiring is correct as you mentioned above.
Can you please try this sensor with your a16 board and check it.??
Thanks.
only hcr501 can't work?
if you short digital input port with GND, home assistant can detected? work well?
HI,
CAN YOU PLEASE SUGGEST SOME PIR MOTION SENSOR WHICH CAN WORK WITH A16 BOARD ??
please post some sensor name and link ?
thanks
just use relay output signal is better, your PIR is use triode output, maybe have level compatibility issues.
here is our PIR sensor, can work for KC868-A16: https://www.aliexpress.us/item/225183279..._shipto=US
I have your pir motion sensor it has 5 wire
Red Black white blue and yellow
Which wire to connect with what ?
https://www.kincony.com/how-to-use-pir-sensor.html
here is diagram. Because our PIR sensor have relay's "COM, NC,NO" output, you just need to use "COM" and "NO" is ok. output is WHITE and YELLOW.
