help me choose the components of a smart system
I have now home  i want used  will use home assistant
 i want used momentary wall switch + 4 IP Camera + sound systems 4 zoom + alexa voice control
and  i want connect  all relay swatch by ethernet to the server between the floor
71  lighting circuits on / off
12 dimmer lighting circuits
6 air conditioner circuits with control keys
3 garage control circuit
4 motor
 6Curtain motor
4  move sensor
_________________________________________
 First floor
32  lighting circuits on / off
6 dimmer lighting circuits
5 air conditioner circuits with control keys
 6 Curtain motor
3  move sensor
Second floor
20 lighting circuits on / off
4 dimmer lighting circuit
2 heater circuit with control switches
3 air conditioner circuit with control switches
2 motor
thank you
I think you need these types of device:
KC868-H32B Pro
KC868-D16 + LED driver
KC868-AG
KC868-AI
AC contactor
1. KC868-H32B Pro is relay controller , mainly use for your light, garage door, curtain motor.
2. KC868-D16 use for your dimmer light.
3. KC868-AG use for send IR signal to control your air conditioner.
4. KC868-AI is a input module , connect with your move sensor.
AC contactor just extend the load current. because smart relay controller relay is 250v 7A MAX, if you want to control large current load, such as your heater circuit, need add the AC contactor, so that can control load by 220V 20A / 40A /60A .....
you just need to calculate the channel number , then decide how many products to use, maybe you will install every controller in every floor.
at last , if you want to install home assistant in KinCony's controller, you can add KC868-Server, if you already have raspberry pi, ok, just install home assistant on that.
thank you for your repay
kind if get time to lock list of systems , any thing missing
1- LOCAL SERVER (RASPBERRY PI) – KC868-SERVER ( I have in my home )
2- KC868-A128 as digital input
3- kc868-E16 V2 as we need
4- KC868-AG ESP IR in etch room
5- KC868-D16 as we need
6 - KC868-AI AC contactor as we need
6- Wired Water Leak Sensor Detector as we need
7- Wired Electronic Smoke Detector Sensor
8- KC868-Uair ESP32 for control TEMP - in etch floor
9- Smart home system Zigbee/GPRS/RF - in etch floor
10- KinCony Zigbee Curtain motor Controller
11- 12V /24V 80W LED Dimmable Driver
12- Win10 Tablet Windows Pad Dashboard
13- Automatic Manipulator Shut Off Valve
14- Wired Water Level Sensor Detector
15- Non-contact liquid water level sensor tank float switch liquid detection alarm
16- momentary wall switch as need it
17 - Door Lock smart
18- move sensor
also i want drawing contention which program give me power for drawing Map contention
thank you
what's these use for ? curtain motor wire you already connect with smart relay controller, not need to use item:10
what's item:9?
9 Check out this product on Alibaba App Smart home system Zigbee/GPRS/RF wireless remote control switch phone electrical appliances for smart home system controller
I will use it with movement sensor
do your "movement sensor" is zigbee or wired?
zigbee
there are two way for Zigbee device:
1. install zigbee USB dongle to KC868-Server's USB port.
2. install another zigbee3.0 gateway.
Can you share link for zigbee USB dongle
Which's model we can use for zigbee3.0 gateway.
[Image: attachment.php?aid=707]
