Threads: 848
To enable the USB 2.0 ports on the Compute Module 4, you need to edit the boot config file (/boot/config.txt) and add:
dtoverlay=dwc2,dr_mode=host
Then reboot the Pi. Now you should be able to use the built-in USB 2.0 ports!
Threads: 848
if you have installed raspberry pi OS, need manually enable SSH function.
Threads: 848
can you use another new SD card install home assistant OS, have a test?
Threads: 848
sorry, i forgot you use eMMC CM4, eMMC CM4 version only use by eMMC, can't use SD card. OK, if you can take a video is better, you can take video and upload to Google driver, then give me your download link, we will check. just use by eMMC.
Threads: 848
do you use Raspberry Pi or CM4?
