Lesson13 - integrate KC868-AG to home assistant control air conditioner by IR
#21
thank you for your support
i try this code but not working for Gree ac
remote_receiver:
    number: GPIO14
    mode:
      input: true
      pullup: true
  # high 55% tolerance is recommended for some remote control units
  tolerance: 55%
climate:
  - platform: greeya
    name: "Living Room AC"
    receiver_id: rcvr
i think this you can feedback to ESPHome forum for a help is better.
Can we use external sensor (Temperature / humidity)  to turn on/off Air Conditioner or Room Fan ?
or
any other device ? to control air conditioner
Thanks & Regards,
Arshad Abbas
Smile
if you have another board , such as KC868-AM connect with DS18B120 temperature sensor. your KC868-AG also is integrate to home asisstant. Then you can set AUTOMATION for that. temperature control send IR signal to air conditioner.
