03-06-2023, 08:07 AM
we have checked , but not find the problem. can you tell me , What can be done to reproduce such a problem, so that we can fix it.
KC868-AK Firmware
03-17-2023, 08:42 AM
Could it be related to Relay Controller Software version. Controller I am using has version H32B_V4.36.
Another thing is that everything works well except that controller is not sending state update in TCP Server mode if any relay was switched on/off by KC868-AK module, could you help with that?
03-17-2023, 08:44 AM
do you want feedback by tcp message? or by mqtt message? mqtt message will feedback relay state if state changed by any way.
03-17-2023, 11:45 AM
yes, I need feedback by tcp message. I would like to avoid using mqtt as I am building a lightweight system with minimal dependencies.
03-17-2023, 12:40 PM
next week , when we work , have a test.
03-19-2023, 02:27 PM
I have updated relay firmware to version 4.44, but unfortunately it still does not work with Keyboard.
Only way how it works is if I put 1-32. Any other combination (e.g 1-31 or 1-12) does not work. This feature is pretty critical for me as I have some master switched in building and they should work with multiple relay outputs. Another thing that I was not able to update relay firmware to version 4.45 or 4.46, after download and press run relay was not working, no LEDs were switched on ![]()
03-20-2023, 01:51 AM
1. we will test it ,feedback later.
2. because begin with V4.45 , firmware size >128k, you need to update your CPU bootloader file, so that can support large new file. take a photo of your H32B pcb board, two side, i need to see your CPU chip model.
03-20-2023, 06:35 PM
H32B need update fimrware to use KC868-AK, H32B Pro is no problem. but you should have ST-Link for update STM32 CPU.
here is st-link cable: https://www.aliexpress.us/item/225183283..._shipto=US H32B will update firmware in furture when our development team have time. when it released, i will update to you.
03-22-2023, 08:38 AM
The development is required to
- H32B will send tcp update when Keyboard will switch any relay? - It will be possible to switch with one key press multiple relays, not only all (1-32) or both? What should I need to do next when I have ST-Link ? |
Users browsing this thread: |
3 Guest(s) |
