09-05-2022, 08:15 AM
(This post was last modified: 09-06-2022, 12:54 AM by KinCony Support.)
[Arduino IDE demo source code for KC868-E16S]--#08-E16S-Ethernet_Web_server_code
Refer to code #11 of KC868-A8 for download methods
KC868-E16S_Web_Server-ETH.zip (Size: 474.02 KB / Downloads: 1,111)
* Create Your own WebServer for KC868-E16S Smart Controller*
* https://www.kincony.com **
#include "PCF8574.h"
#define DEBUG_ETHERNET_WEBSERVER_PORT Serial
// Debug Level from 0 to 4
#define _ETHERNET_WEBSERVER_LOGLEVEL_ 3
WiFiServer server(80);
// Current time
// Previous time
int flag_read_di=0;
String header;
TwoWire I2Cone = TwoWire(0);
TwoWire I2Ctwo = TwoWire(1);
PCF8574 pcf8574_I1(&I2Cone, 0x22, 16, 15);
PCF8574 pcf8574_I2(&I2Cone, 0x24, 16, 15);
PCF8574 pcf8574_R1(&I2Cone, 0x21, 16, 15);
PCF8574 pcf8574_R2(&I2Cone, 0x25, 16, 15);
String relaystate[16]={"relay1state","relay2state","relay3state","relay4state","relay5state","relay6state","relay7state","relay8state",
"relay9state","relay10state","relay11state","relay12state","relay13state","relay14state","relay15state","relay16state",};
for(int i=0;i<=7;i++)
pcf8574_R1.begin();
pcf8574_R2.begin();
pcf8574_I1.pinMode(i, INPUT);
pcf8574_I2.pinMode(i, INPUT);
pcf8574_I1.begin();
pcf8574_I2.begin();
// Connect to Wi-Fi network with SSID and password
// Serial.print("Connecting to ");
// Serial.println(ssid);
while (!Serial);
WT32_ETH01_onEvent();
// eth_phy_type_t type=ETH_PHY_TYPE, eth_clock_mode_t clk_mode=ETH_CLK_MODE);
//WT32_ETH01_waitForConnect();
server.begin();
void loop(){
currentTime = millis();
previousTime = currentTime;
header += c;
client.println();
// turns 16 relays on and off
else if (header.indexOf("GET /7/on") >= 0) {relay7state = "on";pcf8574_R1.digitalWrite(P6, LOW);}
else if (header.indexOf("GET /8/on") >= 0) {relay8state = "on";pcf8574_R1.digitalWrite(P7, LOW);}
else if (header.indexOf("GET /9/on") >= 0) {relay9state = "on";pcf8574_R2.digitalWrite(P0, LOW);}
else if (header.indexOf("GET /10/on") >= 0) {relay10state = "on";pcf8574_R2.digitalWrite(P1, LOW);}
else if (header.indexOf("GET /11/on") >= 0) {relay11state = "on";pcf8574_R2.digitalWrite(P2, LOW);}
else if (header.indexOf("GET /12/on") >= 0) {relay12state = "on";pcf8574_R2.digitalWrite(P3, LOW);}
else if (header.indexOf("GET /13/on") >= 0) {relay13state = "on";pcf8574_R2.digitalWrite(P4, LOW);}
else if (header.indexOf("GET /14/on") >= 0) {relay14state = "on";pcf8574_R2.digitalWrite(P5, LOW);}
else if (header.indexOf("GET /15/on") >= 0) {relay15state = "on";pcf8574_R2.digitalWrite(P6, LOW);}
else if (header.indexOf("GET /16/on") >= 0) {relay16state = "on";pcf8574_R2.digitalWrite(P7, LOW);}
pcf8574_R2.digitalWrite(i, LOW);
// Display the HTML web page
client.println("<style>html { font-family: Helvetica; display: inline-block; border: 3px solid green;margin: 0px 15px;text-align: center;font-size: 10px;}");
if (flag_read_di==1)
client.println(" relay1:" + relay1state + " relay2:" + relay2state + " relay3:" + relay3state + " relay4:" + relay4state + " relay5:" + relay5state + " relay6:" + relay6state + " relay7:" + relay7state + " relay8:" + relay8state + " relay9:" + relay9state + " relay10:" + relay10state + " relay11:" + relay11state + " relay12:" + relay12state + " relay13:" + relay13state + " relay14:" + relay14state + " relay15:" + relay15state + " relay16:" + relay16state);
else
// Web Page Heading
client.println("<body><h1>KC868-E16S Web Server</h1>");
if (relay1state == "off") client.println("<a href=\"/1/on\"><button class=\"button\">01-OFF</button></a>"); else client.println("<a href=\"/1/off\"><button class=\"button\">01--ON </button></a>");
if (relay2state == "off") client.println("<a href=\"/2/on\"><button class=\"button\">02-OFF</button></a>"); else client.println("<a href=\"/2/off\"><button class=\"button\">02--ON </button></a>");
if (relay3state == "off") client.println("<a href=\"/3/on\"><button class=\"button\">03-OFF</button></a>"); else client.println("<a href=\"/3/off\"><button class=\"button\">03--ON </button></a>");
if (relay4state == "off") client.println("<a href=\"/4/on\"><button class=\"button\">04-OFF</button></a>"); else client.println("<a href=\"/4/off\"><button class=\"button\">04--ON </button></a>");
if (relay5state == "off") client.println("<a href=\"/5/on\"><button class=\"button\">05-OFF</button></a>"); else client.println("<a href=\"/5/off\"><button class=\"button\">05--ON </button></a>");
if (relay6state == "off") client.println("<a href=\"/6/on\"><button class=\"button\">06-OFF</button></a>"); else client.println("<a href=\"/6/off\"><button class=\"button\">06--ON </button></a>");
if (relay7state == "off") client.println("<a href=\"/7/on\"><button class=\"button\">07-OFF</button></a>"); else client.println("<a href=\"/7/off\"><button class=\"button\">07--ON </button></a>");
if (relay8state == "off") client.println("<a href=\"/8/on\"><button class=\"button\">08-OFF</button></a>"); else client.println("<a href=\"/8/off\"><button class=\"button\">08--ON </button></a>");
if (relay9state == "off") client.println("<a href=\"/9/on\"><button class=\"button\">09-OFF</button></a>"); else client.println("<a href=\"/9/off\"><button class=\"button\">09--ON </button></a>");
if (relay10state == "off") client.println("<a href=\"/10/on\"><button class=\"button\">10-OFF</button></a>"); else client.println("<a href=\"/10/off\"><button class=\"button\">10--ON</button></a>");
if (relay11state == "off") client.println("<a href=\"/11/on\"><button class=\"button\">11-OFF</button></a>"); else client.println("<a href=\"/11/off\"><button class=\"button\">11--ON</button></a>");
if (relay12state == "off") client.println("<a href=\"/12/on\"><button class=\"button\">12-OFF</button></a>"); else client.println("<a href=\"/12/off\"><button class=\"button\">12--ON</button></a>");
if (relay13state == "off") client.println("<a href=\"/13/on\"><button class=\"button\">13-OFF</button></a>"); else client.println("<a href=\"/13/off\"><button class=\"button\">13--ON</button></a>");
if (relay14state == "off") client.println("<a href=\"/14/on\"><button class=\"button\">14-OFF</button></a>"); else client.println("<a href=\"/14/off\"><button class=\"button\">14--ON</button></a>");
if (relay15state == "off") client.println("<a href=\"/15/on\"><button class=\"button\">15-OFF</button></a>"); else client.println("<a href=\"/15/off\"><button class=\"button\">15--ON</button></a>");
if (relay16state == "off") client.println("<a href=\"/16/on\"><button class=\"button\">16-OFF</button></a>"); else client.println("<a href=\"/16/off\"><button class=\"button\">16--ON</button></a>");
client.println("<a href=\"/all/on\"><button class=\"button\">All--ON</button></a>");
client.println();
break;
currentLine = "";
// Clear the header variable
header = "";
// Close the connection
client.stop();
Serial.println("");
flag_read_di=0;
ScanKey(); //scan key
void ScanKey()
delay(20);
for(int j=0;j<=7;j++)
if(pcf8574_I2.digitalRead(j) == LOW) //key pressed
delay(20);
if(pcf8574_I2.digitalRead(j) == LOW) //key pressed again
pcf8574_R2.digitalWrite(j,!pcf8574_R2.digitalRead(j)); // toggle relay1 state
while(pcf8574_I2.digitalRead(j) == LOW); //wait remove hand
if (pcf8574_R2.digitalRead(j) == LOW) relaystate[j+8]="on";else relaystate[j+8]="off";
