KC868-H32B V4.19 new firmware for MQTT update
improvement:
1. add read input state http command for developer integrate to third-party software. you can send http command to get information of 6 channel digital input port state.
Command is like this, send:  http://192.168.1.xx/sw_ctl.cgi?RelayFF=RD&postpwd=XXXXXX
Then will feedback all state.
2. support use MQTT function by WiFi. it will easy integrate to third-party software, like home assistant...
how to integrate to home assistant by MQTT, see this link: https://www.kincony.com/kc868-h32b-integ...-mqtt.html
3. add option on config webpage, you can chose whether relay will remember the state before power off. Just whether receover relay sate when power on.
4. add option on config webpage, you can chose any relay channel for momentary work mode, and set the delay time for auto off.
KC868-H32B V4.19 firmware download:
download the ZIP file , unzip update the bin file for KC868-H32B relay controller.
.zip   Relay32_V419_210321.zip (Size: 41.45 KB / Downloads: 1,088)
Where can I find the how to update the firmware. I have downloaded the KC868 Controller Bootloader, any specific parameter need to be set?
here is video guide , how to update firmware: https://youtu.be/LLIJe9VTVq8
